Occasional Contributor
MPR connection Fabric ID conflict
Hi,
we start to configure 3 MPR 7800 in 3 different site. We connect the mpr via DWDM in this configuration.
SITE1
MPR1 (SWITCH ID 101
P.0 EX-Port connected to LOCAL FABRIC (trunk1)
P1. EX-Port connected to LOCAL FABRIC (trunk1)
P2. LS-E-Port connected to MPR2 via DWDM
P3. LE-E-Port connected to MPR3 via DWDM
SITE2
MPR2 SWITCH ID 103
P.0 EX-Port connected to LOCAL FABRIC (t1)
P1. EX-Port connected to LOCAL FABRIC (t1)
P2. LS-E-Port connected to MPR1 via DWDM
SITE3
MPR3 SID 105
P3. LE-E-Port connected to MPR2 via DWDM
On site 2 and 3 on port 0 and 1 the port becom Disabled for fabric id conflict, but i unable to find which id is in conflict.
With fcrlogshow i see:
SWPM101:root> fcrlogshow
============================== Main Event Trace ==========================
Chassis log: Tue Jul 10 08:17:55 2018
08:17:55.445662 sw0:iswProcessSCN:pt0 EX_PORT_SCN; subtype EX_ONLINE
08:18:07.677998 sw0:iswd_add_wwn_device_spm:WWN 21000024ff26face added at 12 by 1 hi 25 tot 9
08:18:07.678064 sw0:iswd_add_wwn_device_spm:WWN 2100000d77397108 added at 14 by 1 hi 25 tot 10
08:18:07.679108 sw0:iswd_add_wwn_device_spm:WWN 2100000d7726face added at 11 by 1 hi 25 tot 11
08:18:07.679164 sw0:iswd_add_wwn_device_spm:WWN 21000024ff397108 added at 10 by 1 hi 25 tot 12
08:18:07.680200 sw0:iswd_add_wwn_device_spm:WWN 200124b6fdd807cc added at 9 by 1 hi 25 tot 13
08:18:07.680255 sw0:iswd_add_wwn_device_spm:WWN 50060e80139e4602 added at 8 by 1 hi 25 tot 14
08:18:07.681288 sw0:iswd_add_wwn_device_spm:WWN 50060e80139e4642 added at 16 by 1 hi 25 tot 15
08:18:07.681343 sw0:iswd_add_wwn_device_spm:WWN 50060e80139f0e42 added at 13 by 1 hi 25 tot 16
08:18:07.682374 sw0:iswd_add_wwn_device_spm:WWN 50060e80139e4640 added at 17 by 1 hi 25 tot 17
08:18:07.682431 sw0:iswd_add_wwn_device_spm:WWN 50060e80139f0e40 added at 15 by 1 hi 25 tot 18
08:18:07.683478 sw0:iswd_add_wwn_device_spm:WWN 50060e801651d900 added at 18 by 1 hi 25 tot 19
08:18:07.684506 sw0:iswd_add_wwn_device_spm:WWN 50060e801651d920 added at 20 by 1 hi 25 tot 20
08:18:07.684555 sw0:iswd_add_wwn_device_spm:WWN 50060e8016518720 added at 19 by 1 hi 25 tot 21
08:18:07.686586 sw0:iswd_add_wwn_device_spm:WWN 50060e801651d922 added at 22 by 1 hi 25 tot 22
08:18:07.686640 sw0:iswd_add_wwn_device_spm:WWN 50060e8016518722 added at 21 by 1 hi 25 tot 23
08:18:07.687187 sw0:iswns_online_dev_check_in_edge:pt0 ge_pt check
08:18:07.692580 sw0:iswd_check_export_fabric:7,2
08:18:08.516029 sw0:iswddb_is_eliz_need_to_send:need to send ELIZ of f 2 LSAN_SIR1P_INIT_SIR1M_TARG numdev 2 to domain 105 db:417 ack:0
08:18:08.516907 sw0:iswddb_send_one_lsan_within_bb:No lsan in db to send to domain 103
08:18:08.517032 sw0:iswddb_is_eliz_need_to_send:need to send ELIZ of f 2 LSAN_SIR1P_INIT_SIR1M_TARG numdev 2 to domain 105 db:417 ack:0
08:18:08.517472 sw0:iswddb_eliz_entries_send:sent ELIZ of LSAN_SIR1P_INIT_SIR1M_TARG with 2 entries to did 105 from did 101
08:18:08.521445 sw0:iswddb_eliz_acks_handler:bb_ack_timestamp of LSAN_SIR1P_INIT_SIR1M_TARG ts:417 from domain 105
08:18:08.521669 sw0:iswddb_eliz_acks_handler:domain 105 send next lsan 5
08:18:08.521770 sw0:iswddb_is_eliz_need_to_send:need to send ELIZ of f 2 LSAN_SIR1P_TARG_SIR1M_INIT numdev 2 to domain 105 db:418 ack:0
08:18:08.522279 sw0:iswddb_eliz_entries_send:sent ELIZ of LSAN_SIR1P_TARG_SIR1M_INIT with 2 entries to did 105 from did 101
08:18:08.526482 sw0:iswddb_eliz_acks_handler:bb_ack_timestamp of LSAN_SIR1P_TARG_SIR1M_INIT ts:418 from domain 105
08:18:08.526501 sw0:iswddb_eliz_acks_handler:domain 105 send next lsan 6
08:18:08.526594 sw0:iswddb_is_eliz_need_to_send:need to send ELIZ of f 2 LSAN_VM_Ma_1C_SRVHSMN1_FC1 numdev 2 to domain 105 db:419 ack:0
08:18:08.527051 sw0:iswddb_eliz_entries_send:sent ELIZ of LSAN_VM_Ma_1C_SRVHSMN1_FC1 with 2 entries to did 105 from did 101
08:18:08.536598 sw0:iswddb_eliz_acks_handler:bb_ack_timestamp of LSAN_VM_Ma_1C_SRVHSMN1_FC1 ts:419 from domain 105
08:18:08.536617 sw0:iswddb_eliz_acks_handler:domain 105 send next lsan 7
08:18:08.536711 sw0:iswddb_is_eliz_need_to_send:need to send ELIZ of f 2 LSAN_VM_Ma_5C_Init_VM_Pa_5C_Targ numdev 2 to domain 105 db:420 ack:0
08:18:08.537143 sw0:iswddb_eliz_entries_send:sent ELIZ of LSAN_VM_Ma_5C_Init_VM_Pa_5C_Targ with 2 entries to did 105 from did 101
08:18:08.546718 sw0:iswddb_eliz_acks_handler:bb_ack_timestamp of LSAN_VM_Ma_5C_Init_VM_Pa_5C_Targ ts:420 from domain 105
08:18:08.546736 sw0:iswddb_eliz_acks_handler:domain 105 send next lsan 8
08:18:08.546829 sw0:iswddb_is_eliz_need_to_send:need to send ELIZ of f 2 LSAN_VM_Pa_5A_Init_VM_Ma_5A_Targ numdev 2 to domain 105 db:421 ack:0
08:18:08.547509 sw0:iswddb_eliz_entries_send:sent ELIZ of LSAN_VM_Pa_5A_Init_VM_Ma_5A_Targ with 2 entries to did 105 from did 101
08:18:08.556420 sw0:iswddb_eliz_acks_handler:bb_ack_timestamp of LSAN_VM_Pa_5A_Init_VM_Ma_5A_Targ ts:421 from domain 105
08:18:08.556439 sw0:iswddb_eliz_acks_handler:domain 105 send next lsan 9
08:18:08.556533 sw0:iswddb_is_eliz_need_to_send:need to send ELIZ of f 2 LSAN_VSPMAR_1A_SRVHSMN1_FC1 numdev 2 to domain 105 db:422 ack:0
08:18:08.556971 sw0:iswddb_eliz_entries_send:sent ELIZ of LSAN_VSPMAR_1A_SRVHSMN1_FC1 with 2 entries to did 105 from did 101
08:18:08.566433 sw0:iswddb_eliz_acks_handler:bb_ack_timestamp of LSAN_VSPMAR_1A_SRVHSMN1_FC1 ts:422 from domain 105
08:18:08.566451 sw0:iswddb_eliz_acks_handler:domain 105 send next lsan 10
08:18:08.566545 sw0:iswddb_is_eliz_need_to_send:need to send ELIZ of f 2 LSAN_VSPPAL_3A_INIT_VSPMAR_3A_TARG numdev 2 to domain 105 db:423 ack:0
08:18:08.567000 sw0:iswddb_eliz_entries_send:sent ELIZ of LSAN_VSPPAL_3A_INIT_VSPMAR_3A_TARG with 2 entries to did 105 from did 101
08:18:08.576562 sw0:iswddb_eliz_acks_handler:bb_ack_timestamp of LSAN_VSPPAL_3A_INIT_VSPMAR_3A_TARG ts:423 from domain 105
08:18:08.576580 sw0:iswddb_eliz_acks_handler:domain 105 send next lsan 11
08:18:08.576675 sw0:iswddb_is_eliz_need_to_send:need to send ELIZ of f 2 LSAN_VSPPAL_3C_INIT_VSPMAR_3C_TARG numdev 2 to domain 105 db:424 ack:0
08:18:08.577117 sw0:iswddb_eliz_entries_send:sent ELIZ of LSAN_VSPPAL_3C_INIT_VSPMAR_3C_TARG with 2 entries to did 105 from did 101
08:18:08.586389 sw0:iswddb_eliz_acks_handler:bb_ack_timestamp of LSAN_VSPPAL_3C_INIT_VSPMAR_3C_TARG ts:424 from domain 105
08:18:08.586408 sw0:iswddb_eliz_acks_handler:domain 105 send next lsan 12
08:18:08.587369 sw0:iswddb_send_one_lsan_within_bb:No lsan in db to send to domain 105
08:18:09.029562 sw0:iswProcessSCN:pt0 scn subtype EX_OFFLINE reason 10004
08:18:09.084216 sw0:iswddb_tbd_izone_add:tbd_izone 0 LSAN_VSPPAL_3C_INIT_VSPMAR_3C_TARG fabric 2 ts 425 forced 0 added to to-be-del lst
08:18:09.084300 sw0:iswd_remove_wwn_device_spm:WWN 50060e801651d922 at 22 removed hi 25 tot 22
08:18:09.084356 sw0:iswd_remove_wwn_device_spm:WWN 50060e8016518722 at 21 removed hi 25 tot 21
08:18:09.084401 sw0:iswddb_tbd_izone_add:tbd_izone 1 LSAN_VSPPAL_3A_INIT_VSPMAR_3A_TARG fabric 2 ts 426 forced 0 added to to-be-del lst
08:18:09.084435 sw0:iswd_remove_wwn_device_spm:WWN 50060e801651d920 at 20 removed hi 25 tot 20
08:18:09.084471 sw0:iswd_remove_wwn_device_spm:WWN 50060e8016518720 at 19 removed hi 25 tot 19
08:18:09.084504 sw0:iswddb_tbd_izone_add:tbd_izone 2 LSAN_VSPMAR_1A_SRVHSMN1_FC1 fabric 2 ts 427 forced 0 added to to-be-del lst
08:18:09.084544 sw0:iswd_remove_wwn_device_spm:WWN 50060e801651d900 at 18 removed hi 25 tot 18
08:18:09.084577 sw0:iswddb_tbd_izone_add:tbd_izone 3 LSAN_VM_Pa_5A_Init_VM_Ma_5A_Targ fabric 2 ts 428 forced 0 added to to-be-del lst
08:18:09.084613 sw0:iswd_remove_wwn_device_spm:WWN 50060e80139e4640 at 17 removed hi 25 tot 17
08:18:09.084651 sw0:iswd_remove_wwn_device_spm:WWN 50060e80139f0e40 at 15 removed hi 25 tot 16
08:18:09.084685 sw0:iswddb_tbd_izone_add:tbd_izone 4 LSAN_VM_Ma_5C_Init_VM_Pa_5C_Targ fabric 2 ts 429 forced 0 added to to-be-del lst
08:18:09.084720 sw0:iswd_remove_wwn_device_spm:WWN 50060e80139e4642 at 16 removed hi 25 tot 15
08:18:09.084757 sw0:iswd_remove_wwn_device_spm:WWN 50060e80139f0e42 at 13 removed hi 25 tot 14
08:18:09.084794 sw0:iswddb_tbd_izone_add:tbd_izone 5 LSAN_VM_Ma_1C_SRVHSMN1_FC1 fabric 2 ts 430 forced 0 added to to-be-del lst
08:18:09.084828 sw0:iswd_remove_wwn_device_spm:WWN 200124b6fdd807cc at 9 removed hi 25 tot 13
08:18:09.084865 sw0:iswd_remove_wwn_device_spm:WWN 50060e80139e4602 at 8 removed hi 25 tot 12
08:18:09.084898 sw0:iswddb_tbd_izone_add:tbd_izone 6 LSAN_SIR1P_TARG_SIR1M_INIT fabric 2 ts 431 forced 0 added to to-be-del lst
08:18:09.084932 sw0:iswd_remove_wwn_device_spm:WWN 2100000d7726face at 11 removed hi 25 tot 11
08:18:09.084970 sw0:iswd_remove_wwn_device_spm:WWN 21000024ff397108 at 10 removed hi 25 tot 10
08:18:09.085004 sw0:iswddb_tbd_izone_add:tbd_izone 7 LSAN_SIR1P_INIT_SIR1M_TARG fabric 2 ts 432 forced 0 added to to-be-del lst
08:18:09.085038 sw0:iswd_remove_wwn_device_spm:WWN 21000024ff26face at 12 removed hi 25 tot 9
08:18:09.085075 sw0:iswd_remove_wwn_device_spm:WWN 2100000d77397108 at 14 removed hi 25 tot 8
08:18:09.085131 sw0:iswddb_tbd_izone_send_help:total 8 numiu sent 1 to dom 103
08:18:09.085779 sw0:iswddb_tbd_izone_send_help:sent 8 tbd_izone of fid 2 to did 103 from did 101
08:18:09.085794 sw0:iswddb_tbd_izone_send_help:total 8 numiu sent 1 to dom 105
08:18:09.086225 sw0:iswddb_tbd_izone_send_help:sent 8 tbd_izone of fid 2 to did 105 from did 101
08:18:09.086269 sw0:iswd_check_export_fabric:6,2
08:18:09.153429 sw0:iswddb_tbd_izone_acks_handler:receive 8 tbd_acks from dom 105
08:18:09.153556 sw0:iswddb_tbd_izone_acks_handler:receive 8 tbd_acks from dom 103
08:18:09.516744 sw0:iswddb_send_one_lsan_within_bb:No lsan in db to send to domain 103
08:18:09.516753 sw0:iswddb_recal_lsan_sent_for_other_dom:Remove dom 105 from sent list
08:18:09.516861 sw0:iswd_periodic_check_export:pair match time: 2000 reason 6
08:18:09.517043 sw0:iswd_periodic_check_export:reason 6 rdi: 0 done full trans: 0 import: 0 check: 0 in 0 ms 0 tk
08:18:09.521870 sw0:iswddb_tbd_izone_delete:tbd_izone LSAN_VSPPAL_3C_INIT_VSPMAR_3C_TARG 2 at 0 deleted
08:18:09.521939 sw0:iswddb_tbd_izone_delete:tbd_izone LSAN_VSPPAL_3A_INIT_VSPMAR_3A_TARG 2 at 1 deleted
08:18:09.521987 sw0:iswddb_tbd_izone_delete:tbd_izone LSAN_VSPMAR_1A_SRVHSMN1_FC1 2 at 2 deleted
08:18:09.522034 sw0:iswddb_tbd_izone_delete:tbd_izone LSAN_VM_Pa_5A_Init_VM_Ma_5A_Targ 2 at 3 deleted
08:18:09.522082 sw0:iswddb_tbd_izone_delete:tbd_izone LSAN_VM_Ma_5C_Init_VM_Pa_5C_Targ 2 at 4 deleted
08:18:09.522130 sw0:iswddb_tbd_izone_delete:tbd_izone LSAN_VM_Ma_1C_SRVHSMN1_FC1 2 at 5 deleted
08:18:09.522179 sw0:iswddb_tbd_izone_delete:tbd_izone LSAN_SIR1P_TARG_SIR1M_INIT 2 at 6 deleted
08:18:09.522226 sw0:iswddb_tbd_izone_delete:tbd_izone LSAN_SIR1P_INIT_SIR1M_TARG 2 at 7 deleted
08:18:10.516723 sw0:iswddb_send_one_lsan_within_bb:No lsan in db to send to domain 103
08:18:10.516732 sw0:iswddb_recal_lsan_sent_for_other_dom:Remove dom 105 from sent list
============================== Regular Trace =================================
08:17:55.444712 sw0:iswIuHandler:received IU on port 0 from edge but not up
08:17:55.466746 sw0:iswzn_group_clear_by_fabric:fabric 2 freed zone groups
08:17:55.466794 sw0:iswu_fd_full_state_clr:slot 0 fabric 2 fd struct is getting cleared
08:17:55.472425 sw0:iswu_fd_alloc_list_set:allocate fd structure for slot 0 fabric 2 index 0
08:17:55.472714 sw0:iswp_fspf_reachable_clear:pt0 reachable table is cleared
08:17:55.508940 sw0:iswp_lsr_send_state_set: pt0 send STATE = 0
08:17:55.509045 sw0:iswha_open_sfc_send:pt0 has invalid rdi_port -1
08:17:55.509406 sw0:iswp_elp_opmode_retry_count_clear:pt0 elp count set to 0
08:17:55.509480 sw0:iswauth_cleanup:pt0 cleanup auth.
08:17:55.509491 sw0:iswauth_dhChapCleanupPort:palloc is null pt0
08:17:55.509498 sw0:iswauth_cleanup:pt0 cleanup auth done.
08:17:55.509542 sw0:isw_b2e_psm_send_event:pt0 got event INIT in state UNINIT
08:17:55.509550 sw0:iswpsm_b2e_uninit:pt0 b2e event 1
08:17:55.509558 sw0:iswp_b2e_xlate_domain_set:pt0 force bb xlate to 0
08:17:55.509566 sw0:iswp_b2e_old_xlate_domain_set:pt0 bb xlate to 0
08:17:55.509582 sw0:iswp_b2e_old_owner_pid_set:pt0 set old owner pid to 0
08:17:55.509598 sw0:iswp_b2e_out_port_set:pt0 set out portto ffffffff
08:17:55.509628 sw0:iswp_b2e_lsu_timer_init:pt0 lsu timer initialized
08:17:55.509638 sw0:iswp_b2e_hlo_poll_count_set:pt0 set hlo count to 0
08:17:55.509659 sw0:iswp_b2e_elp_opmode_retry_count_clear:pt0 elp count set to 0
08:17:55.509672 sw0:isw_b2e_psm_state_state:pt0 set state from UNINIT to INIT
08:17:55.509685 sw0:iswpsm_b2e_uninit:pt0 b2e event 1 done
08:17:55.515852 sw0:isw_async_task:MSG_ISW_L2_COST_SET EX 0 10000
08:17:59.528279 sw0:isw_config_do_save_port:Save file done
08:17:59.755635 sw0:isw_config_check_save_file:took 227 ms
08:18:01.447862 sw0:isw_ge_iu_handler:pt0 RECV Edge ELP oxid=51ef
08:18:01.447885 sw0:fcrElpReceive:pt0 fctl_len 80 mode 1 port_op_mode 0 rev 2 from_ls 0 op_mode 0x604400
08:18:01.447890 sw0:fcrElpReceive:pt0 elp iu_data_sz 164 tag 1 ELP sz 164
08:18:01.449286 sw0:fcrElp:pt0 Sending ELP Request
08:18:01.449343 sw0:iswu_fd_nwwn_index_get:fabric_id 2 fd_nwwn index 2 exists
08:18:01.449351 sw0:iswu_fd_nwwn_index_set:slot 0 fabric_id 2 fd_nwwn index 2
08:18:01.449614 sw0:fcrElp:pt0 mode 1 num_vcs 8 sz 164
08:18:01.449708 sw0:fcrElp:pt0 bb_sc_n rem:0x8 lcl:0x0
08:18:01.449715 sw0:fcrElp:pt0 total credit = 17
08:18:01.449757 sw0:isw_fill_auto_elp_params:pt0 Using incoming RATOV = 10000 EDTOV = 2000, PID = 400 mode = 1
08:18:01.449872 sw0:isw_portFecOpmodeSet:pt0 capfec:0, CfgIsFEC:1
08:18:01.449880 sw0:fcrElp:pt0 FEC is not enabled
08:18:01.449920 sw0:iswPortEncComp:fop_mode:4400
08:18:01.449927 sw0:fcrElp:pt0 local op_mode = 0x4400 remote 0x604400
08:18:01.453127 sw0:fcrElpSolAcc:pt0 Received ELP Response
08:18:01.453551 sw0:isw_fabOpmodeCmp:pt0 local_op:4400, remote_op:404400
08:18:01.453581 sw0:iswInitiatorTsetup:pt0 iswInitiatorTcapable
08:18:01.456116 sw0:iswSpeedOk:pt0 speed 8
08:18:01.456123 sw0:iswInitiatorTsetup:pt0 iswEmtSetup
08:18:01.456187 sw0:iswInitiatorTsetup:pt0 iswInitiateEmt
08:18:01.456193 sw0:iswInitiateEmt:pt0 sending MARK
08:18:01.456390 sw0:iswEmt:pt0 sends EMT
08:18:01.456943 sw0:fcrElpSolRsp:pt0 trunkable
08:18:01.466244 sw0:iswEmtSolAcc:pt0 EMT ACC
08:18:01.466436 sw0:iswGetMPorts:pt0 trunk->pm_num 0 ports 0 0 0
08:18:01.466441 sw0:iswGetMPorts:pt0 1 trunkable groups
08:18:01.466479 sw0:iswEtpSend:pt0, sending ETP for master port 0
08:18:01.466484 sw0:iswEtp:pt0 trunkable with 0
08:18:01.466535 sw0:iswEtp:pt0 send ETP
08:18:01.486208 sw0:iswEtpSolAcc:pt0 with master 0
08:18:01.486215 sw0:iswEtpSolAcc:pt0, ETP ACC setting master port 0
08:18:01.486329 sw0:iswEtpSolAcc:pt0: Link Reset
08:18:01.486428 sw0:iswEtpNewStart:pt0 port 7 is in state 0
08:18:01.486433 sw0:iswEtpNewStart:pt0 port 3 is in state 0
08:18:01.486437 sw0:iswEtpNewStart:pt0 port 6 is in state 0
08:18:01.486440 sw0:iswEtpNewStart:pt0 port 2 is in state 0
08:18:01.486444 sw0:iswEtpNewStart:pt0 port 5 is in state 0
08:18:01.486448 sw0:iswEtpNewStart:pt0 port 1 is in state 0
08:18:01.486451 sw0:iswEtpNewStart:pt0 port 4 is in state 0
08:18:01.592239 sw0:iswProcessSCN:pt0 rcvd AC_PORT
08:18:01.592264 sw0:iswplat_port_fabric_id_set:pt0 set sfid 2
08:18:04.913376 sw0:isw_config_check_save_file:took 384 ms
08:18:05.597870 sw0:isw_ge_iu_handler:pt0 Processing Native Brcd ESC
08:18:05.607753 sw0:iswf_efp_handler:pt0 port fabric state of 1 100000051e362ed4 priority 2 efp payload count of 3
08:18:05.607815 sw0:iswf_non_rdi_port_handler:pt0 rdi_port -1
08:18:05.607835 sw0:iswf_rdi_send:pt0 asking for domain 3 550eb1ab5168e02 front ? 1
08:18:05.608990 sw0:iswf_efp_handler:pt0 set 10 valid before front valid
08:18:05.609008 sw0:iswf_efp_handler:pt0 set 15 valid before front valid
08:18:05.609013 sw0:iswf_efp_handler:pt0 set 19 valid before front valid
08:18:05.626451 sw0:iswf_rdi_handler:pt0 domain 3 for 550eb1ab5168e02
08:18:05.626458 sw0:iswf_rdi_handler:pt0 domain assigned is 3
08:18:05.626509 sw0:iswp_front_domain_set:pt0 dl_front_domain taken up 0 3
08:18:05.626523 sw0:iswplat_domain_add_by_port:pt0 add domain 3 fabric 0
08:18:05.630253 sw0:iswfspf_hlo_handler:pt0 u hlo 19 options 0 helloInterval 20 deadTimeout 80 remSwitch ffffffff outPort 46 state 1
08:18:05.630287 sw0:iswfspf_hlo_handler:pt0 allocated 129 to go to edge
08:18:05.636781 sw0:iswfspf_lsu_handler:pt0 command 15000000 version 2 sectionId 0 auType 0 switchId 19 uFlag 1
08:18:05.637039 sw0:iswfspf_reachable_parsing:pt0 domain 10 with 2 links
08:18:05.637104 sw0:iswfspf_reachable_parsing:pt0 domain 10 can reach domain 15 15
08:18:05.637110 sw0:iswfspf_reachable_parsing:pt0 domain 15 with 6 links
08:18:05.637148 sw0:iswfspf_reachable_parsing:pt0 domain 15 can reach domain 10 19 19 19 19 10
08:18:05.637152 sw0:iswfspf_reachable_parsing:pt0 domain 19 with 4 links
08:18:05.637181 sw0:iswfspf_reachable_parsing:pt0 domain 19 can reach domain 15 15 15 15
08:18:05.637865 sw0:iswfspf_send_lsa:pt0 lsa sent
08:18:05.638034 sw0:iswfspfdb_dbInstall:lsdb_size_check:fid2 domain10lsr len 60 link cnt2
08:18:05.638086 sw0:iswfspfdb_dbInstall:lsdb_size_check:fid2 domain15lsr len 124 link cnt6
08:18:05.638126 sw0:iswfspfdb_dbInstall:lsdb_size_check:fid2 domain19lsr len 92 link cnt4
08:18:05.646289 sw0:iswfspf_lsu_handler:pt0 command 15000000 version 2 sectionId 0 auType 0 switchId 19 uFlag 3
08:18:05.646739 sw0:iswfspf_remember_incarn:Invalid domain 0
08:18:05.646752 sw0:iswfspf_lsu_handler:pt0 got the end of DB for LSU while the lsr state is 1
08:18:05.646770 sw0:iswp_lsr_send_state_set: pt0 send STATE = 1
08:18:05.647204 sw0:iswfspf_send_lsa:pt0 lsa sent
08:18:06.515899 sw0:iswp_last_sent_incarn_set: pt0 sent incarn = 80000002
08:18:06.515910 sw0:iswfspf_send_domain_only_lsu_internal:pt0 id 3 incarn 80000002
08:18:06.516308 sw0:iswfspf_send_domain_only_lsu_internal:pt0 lsu sent
08:18:06.516653 sw0:iswfspf_send_empty_lsu:pt0 lsu sent
08:18:06.516672 sw0:iswp_lsr_send_state_set: pt0 send STATE = 2
08:18:06.516679 sw0:iswp_lsr_sent_time_set: pt0 send time = 0
08:18:06.562030 sw0:iswfspf_lsa_handler:pt0 LSA of 1 entries
08:18:06.562040 sw0:iswfspf_lsa_handler:pt0 LSA of 3 80000002
08:18:06.562070 sw0:iswfspf_front_lsa:pt0 front LSA of 3 80000002 state 2
08:18:06.562094 sw0:iswp_lsr_send_state_set: pt0 send STATE = 1
08:18:06.562102 sw0:iswfspf_front_lsa:pt0 fspf done
08:18:06.562555 sw0:iswfspf_add_to_router_port_database:pt0 is not done with fabric
08:18:06.582636 sw0:iswfspf_lsu_handler:pt0 command 15000000 version 2 sectionId 0 auType 0 switchId 19 uFlag 0
08:18:06.582887 sw0:iswfspf_reachable_parsing:pt0 domain 19 with 5 links
08:18:06.582961 sw0:iswfspf_reachable_parsing:pt0 domain 19 can reach domain 3 15 15 15 15
08:18:06.583621 sw0:iswfspf_send_lsa:pt0 lsa sent
08:18:06.583760 sw0:iswfspfdb_install_lsu_in_lsdb:lsdb_delete4: is called
08:18:06.583771 sw0:iswfspfdb_remove_lsr_from_lsdb:lsdb_delete_send: fid2 for domain19
08:18:06.583830 sw0:iswfspfdb_dbInstall:lsdb_size_check:fid2 domain19lsr len 108 link cnt5
08:18:06.613807 sw0:iswfspf_lsa_handler:pt0 LSA of 0 entries
08:18:07.515857 sw0:iswfspf_send_full_lsu_internal:pt0 front: 3 with 1 ex_ports xlates: 0 owns:0 to other fronts:0 uflag:0
08:18:07.515915 sw0:iswp_last_sent_incarn_set: pt0 sent incarn = 80000003
08:18:07.515922 sw0:iswfspf_send_full_lsu_internal:pt0 id 3 incarn 80000003
08:18:07.515957 sw0:iswfspf_send_full_lsu_internal:pt0 done with front domain
08:18:07.516419 sw0:iswfspf_send_full_lsu_internal:pt0 lsu sent
08:18:07.516439 sw0:iswp_lsr_send_state_set: pt0 send STATE = 2
08:18:07.516448 sw0:iswp_lsr_sent_time_set: pt0 send time = 0
08:18:07.516647 sw0:iswfspfdb_dbInstall:lsdb_size_check:fid2 domain3lsr len 44 link cnt1
08:18:07.520597 sw0:iswfspf_lsa_handler:pt0 LSA of 1 entries
08:18:07.520608 sw0:iswfspf_lsa_handler:pt0 LSA of 3 80000003
08:18:07.520637 sw0:iswfspf_front_lsa:pt0 front LSA of 3 80000003 state 3
08:18:07.520656 sw0:iswp_lsr_send_state_set: pt0 send STATE = 3
08:18:07.599846 sw0:iswms_ms_handler:pt0 no ct_code (e021) handled
08:18:07.606934 sw0:iswf_ex_lf_conflict_check:pt0 parse ESS size 2296 from dom 19
08:18:07.606948 sw0:iswf_ex_lf_conflict_check:domain 19 supports processing of CSW RSCN
08:18:07.606973 sw0:iswf_ex_lf_conflict_check:domain 19 can process INQ Request with data
08:18:07.606981 sw0:iswf_ex_lf_conflict_check:VF off for dom 19
08:18:07.606993 sw0:iswf_ex_lf_conflict_check:found LF flag 1
08:18:07.607844 sw0:iswrcs_info_handler:pt0 accepted rcs info
08:18:07.608712 sw0:iswzn_check_merge_send:pt0 sent empty zone merge request
08:18:07.609475 sw0:isw_ct_handler:pt0 unknown MS subtype e5
08:18:07.636375 sw0:iswf_inq_handler:pt0 not done with fabric build (6, 3) for domain 3
08:18:07.636763 sw0:iswms_ms_handler:pt0 no ct_code (e021) handled
08:18:07.647071 sw0:iswf_ex_lf_conflict_check:pt0 parse ESS size 2296 from dom 15
08:18:07.647084 sw0:iswf_ex_lf_conflict_check:domain 15 supports processing of CSW RSCN
08:18:07.647111 sw0:iswf_ex_lf_conflict_check:domain 15 can process INQ Request with data
08:18:07.647119 sw0:iswf_ex_lf_conflict_check:VF off for dom 15
08:18:07.647131 sw0:iswf_ex_lf_conflict_check:found LF flag 1
08:18:07.647664 sw0:iswrcs_info_handler:pt0 accepted rcs info
08:18:07.656847 sw0:isw_ct_handler:pt0 unknown MS subtype e5
08:18:07.666522 sw0:iswzn_check_merge_resp:pt0 rejected merge mode as expected
08:18:07.676427 sw0:iswzn_payload_process:pt0 process zone payload.
08:18:07.676445 sw0:iswzn_payload_process:pt0 rev 8c op 22 type 0 sz 960
08:18:07.676451 sw0:iswzn_payload_process: iu_data_sz = 960
08:18:07.676456 sw0:iswzn_payload_process:cfgBuflen = *buflen(928)
08:18:07.676467 sw0:iswzn_payload_process:After Swap strlen(n) = 16, l = 0x11523b00, n = 0x11523aec
08:18:07.676473 sw0:iswzn_payload_process:l - n = 20 buflen = 0x11523b04, *buflen = -1610416128, cfgBufLen = 928, buflen - l = 4
08:18:07.676485 sw0:iswzn_merge_parse:pt0 cfg len 960
08:18:07.676563 sw0:iswzn_group_add:pt0 added AD_flattened_cfg
08:18:07.676601 sw0:iswzn_group_add:pt0 added LSAN_SIR1P_INIT_SIR1M_TARG
08:18:07.676631 sw0:iswzn_group_add:pt0 added LSAN_SIR1P_TARG_SIR1M_INIT
08:18:07.676660 sw0:iswzn_group_add:pt0 added LSAN_VM_Ma_1C_SRVHSMN1_FC1
08:18:07.676694 sw0:iswzn_group_add:pt0 added LSAN_VM_Ma_5C_Init_VM_Pa_5C_Targ
08:18:07.676726 sw0:iswzn_group_add:pt0 added LSAN_VM_Pa_5A_Init_VM_Ma_5A_Targ
08:18:07.676932 sw0:iswzn_group_add:pt0 added LSAN_VSPMAR_1A_SRVHSMN1_FC1
08:18:07.676983 sw0:iswzn_group_add:pt0 added LSAN_VSPPAL_3A_INIT_VSPMAR_3A_TARG
08:18:07.677014 sw0:iswzn_group_add:pt0 added LSAN_VSPPAL_3C_INIT_VSPMAR_3C_TARG
08:18:07.677022 sw0:iswzn_merge_parse:pt0 AD_flattened_cfg enabled
08:18:07.677043 sw0:iswzn_enable_parse:pt0 enable AD_flattened_cfg
08:18:07.677058 sw0:iswzn_enable_parse:pt0 enable AD_flattened_cfg LSAN_SIR1P_INIT_SIR1M_TARG;LSAN_SIR1P_TARG_SIR1M_INIT;LSAN_VM_Ma_1C_SRVHSMN1_FC1;LSAN_VM_Ma_5C_Init_
08:18:07.677068 sw0:iswzn_enable_parse_list:pt0 enable parse list for_bb 0.
08:18:07.687283 sw0:iswzn_enable_parse_list:pt0 enable parse list done.
08:18:07.692631 sw0:iswzn_enable_parse:pt0 enable parse done.
08:18:07.692636 sw0:iswzn_merge_parse:pt0 zone resource ok
08:18:07.692644 sw0:iswzn_merge_parse:pt0 done
08:18:07.692662 sw0:iswzn_payload_process:pt0 process zone payload done.
08:18:07.706449 sw0:iswms_gpl_handler:pt0 received gpl command for 550eb1ab5168e02
08:18:07.707247 sw0:iswf_inq_handler:pt0 not done with fabric build (6, 3) for domain 3
08:18:07.726697 sw0:iswms_ms_handler:pt0 no ct_code (e021) handled
08:18:07.738459 sw0:iswf_ex_lf_conflict_check:pt0 parse ESS size 2112 from dom 10
08:18:07.738473 sw0:iswf_ex_lf_conflict_check:domain 10 supports processing of CSW RSCN
08:18:07.738501 sw0:iswf_ex_lf_conflict_check:VF off for dom 10
08:18:07.738513 sw0:iswf_ex_lf_conflict_check:found LF flag 0
08:18:07.746638 sw0:iswrcs_info_handler:pt0 accepted rcs info
08:18:07.756713 sw0:isw_ct_handler:pt0 unknown MS subtype e5
08:18:07.796461 sw0:iswms_gpl_handler:pt0 received gpl command for 550eb1ab5168e02
08:18:07.806360 sw0:iswf_inq_handler:pt0 not done with fabric build (6, 3) for domain 3
08:18:09.013856 sw0:iswf_efp_handler:pt0 port fabric state of 6 100000051e362ed4 priority 2 efp payload count of 4
08:18:09.013872 sw0:iswf_non_rdi_port_handler:pt0 rdi_port 0
08:18:09.014136 sw0:iswf_efp_handler:pt0 fabric done
08:18:09.014619 sw0:iswf_markex_port_forall_masterports:pt0 marking as true eport
08:18:09.014910 sw0:iswrp_router_port_p_s_wwn_update:pt0 change principal switch wwn to 100000051e362ed4
08:18:09.015053 sw0:iswrp_is_rp_fab_tag_conflict:found 1st conflict router 670000
08:18:09.015117 sw0:iswfspf_add_to_router_port_database:pt0 fid conflict 10:00:00:05:1e:36:2e:d4 with 10:00:00:05:1e:36:26:28, disable
08:18:09.023646 sw0:iswrp_reachable_fabric_update_by_port:pt0 front 3 fabric 128 not reachable. now is *****
08:18:09.023859 sw0:iswp_reachable_to_edge_fabric_set:pt0 connected fabric 128
08:18:09.023898 sw0:iswef_ready_to_revote_fabric:pt0 is ready to revote on fabric 128 xlate 0 wwn 00
08:18:09.024134 sw0:iswf_efp_handler:pt0 domain 3 added
08:18:09.024178 sw0:iswf_efp_handler:pt0 domain 3 sent hlo before done. edge flag up for the port
08:18:09.024203 sw0:iswf_efp_handler:pt0 domain 10 added
08:18:09.024218 sw0:iswf_efp_handler:pt0 domain 10 looks to be real
08:18:09.024619 sw0:iswf_efp_handler:pt0 domain 15 added
08:18:09.024654 sw0:iswf_efp_handler:pt0 domain 15 looks to be real
08:18:09.024963 sw0:iswf_efp_handler:pt0 domain 19 added
08:18:09.024998 sw0:iswf_efp_handler:pt0 domain 19 looks to be real
08:18:09.029593 sw0:iswProcessSCN:pt0 EX_PORT_SCN; subtype EX_OFFLINE
08:18:09.029633 sw0:isw_port_offline:pt0 offlined 0
08:18:09.029649 sw0:iswplat_domain_del_by_port:pt0 delete domain 3 fabric 0
08:18:09.029997 sw0:iswp_fspf_reachable_clear:pt0 reachable table is cleared
08:18:09.083668 sw0:iswp_lsr_send_state_set: pt0 send STATE = 0
08:18:09.084116 sw0:iswp_elp_opmode_retry_count_clear:pt0 elp count set to 0
08:18:09.086336 sw0:iswzn_group_clear_by_fabric:fabric 2 freed zone groups
08:18:09.086407 sw0:iswu_fd_full_state_clr:slot 0 fabric 2 fd struct is getting cleared
08:18:09.094871 sw0:iswplat_router_port_purge_by_port:pt0 call kernel to purge fabroutes
08:18:09.095731 sw0:iswp_enc_mode_set:pt0 encryption mode 0 set
08:18:09.095752 sw0:iswp_comp_mode_set:pt0 compression mode 0 set
08:18:09.095759 sw0:iswp_fec_mode_set:pt0 fec mode 0 set
08:18:09.095776 sw0:iswauth_cleanup:pt0 cleanup auth.
08:18:09.095791 sw0:iswauth_dhChapCleanupPort:palloc is null pt0
08:18:09.095798 sw0:iswauth_cleanup:pt0 cleanup auth done.
08:18:09.098350 sw0:iswProcessSCN:pt0 sfid cleared
08:18:09.098442 sw0:iswProcessSCN:pt0 disabled, so taking down LE port
08:18:09.098457 sw0:isw_b2e_psm_send_event:pt0 got event REMOVED in state INIT
08:18:09.098465 sw0:iswpsm_b2e_init:pt0 b2e event 15
08:18:09.098473 sw0:iswp_b2e_xlate_domain_set:pt0 force bb xlate to 0
08:18:09.099112 sw0:iswplat_le_port_state_set:pt0 ret=0
08:18:09.099133 sw0:isw_b2e_psm_state_state:pt0 set state from INIT to UNINIT
08:18:09.099218 sw0:iswp_fspf_reachable_clear:pt0 reachable table is cleared
08:18:09.152479 sw0:iswp_lsr_send_state_set: pt0 send STATE = 0
08:18:09.152577 sw0:iswha_open_sfc_send:pt0 has invalid rdi_port -1
08:18:09.152934 sw0:iswp_elp_opmode_retry_count_clear:pt0 elp count set to 0
08:18:09.152958 sw0:fcrTrunkCleanUp:pt0 state = 1
08:18:09.152977 sw0:iswha_secure_fabric_send:invalid port -1
08:18:09.152983 sw0:iswha_zone_rcs_send:invalid port -1
08:18:09.152991 sw0:iswfspfdb_lsdb_remove:lsdb_delete1: is called
08:18:09.153003 sw0:iswfspfdb_remove_lsr_from_lsdb:lsdb_delete_send: fid2 for domain3
08:18:09.153031 sw0:iswfspfdb_lsdb_remove:lsdb_delete1: is called
08:18:09.153040 sw0:iswfspfdb_remove_lsr_from_lsdb:lsdb_delete_send: fid2 for domain10
08:18:09.153060 sw0:iswfspfdb_lsdb_remove:lsdb_delete1: is called
08:18:09.153069 sw0:iswfspfdb_remove_lsr_from_lsdb:lsdb_delete_send: fid2 for domain15
08:18:09.153088 sw0:iswfspfdb_lsdb_remove:lsdb_delete1: is called
08:18:09.153097 sw0:iswfspfdb_remove_lsr_from_lsdb:lsdb_delete_send: fid2 for domain19
08:18:09.153347 sw0:iswu_fd_alloc_list_clear:free fd structure for slot 0 fabric 2 index 0
08:18:09.153695 sw0:iswProcessSCN:pt0 LE_PORT_SCN SCN; subtype OFFLINE
08:18:09.521942 sw0:iswha_tbd_send:Delete tbdzone i 0
08:18:09.521992 sw0:iswha_tbd_send:Delete tbdzone i 1
08:18:09.522040 sw0:iswha_tbd_send:Delete tbdzone i 2
08:18:09.522088 sw0:iswha_tbd_send:Delete tbdzone i 3
08:18:09.522135 sw0:iswha_tbd_send:Delete tbdzone i 4
08:18:09.522184 sw0:iswha_tbd_send:Delete tbdzone i 5
08:18:09.522232 sw0:iswha_tbd_send:Delete tbdzone i 6
08:18:09.522287 sw0:iswha_tbd_send:Delete tbdzone i 7
08:18:09.522822 sw0:iswrp_local_rp_entry_send_v8:sent iswLRNE of 0 entries to did 103 from did 101
08:18:09.523219 sw0:iswrp_local_rp_entry_send_v8:sent iswLRNE of 0 entries to did 105 from did 101
08:18:09.526311 sw0:iswrp_lrna_handler:received LRNA for router node 800065
08:18:09.526381 sw0:iswrp_lrna_handler:received LRNA for router node 800065
so i supposed that the switch with10:00:00:05:1e:36:2e:d4 and 10:00:00:05:1e:36:26:28, but the id of this switch are 30 and 1, while MPR1, MPR2 and MPR3 are 101, 102, and 103.
I don't understand why FID is in conflict and how can change it?
Thanks
Frequent Contributor
Re: MPR connection Fabric ID conflict
FID and Domain ID are different things. In your setup, you seem to have four different fabrics, three edges on three sites, and one backbone with FCRs. Three edge fabrics should have different FIDs, which is setup together with the EX port setup on the FCRs, if my memory doesn't cheat me. Did you specify unique FIDs for the EX ports at each FCR?
