Anonymous
Lost connection with switch during fw-upgrade.
The switch was not able to load the fw, it tryed over and over again but the job was canceled. As this was an edge-switch and I had free ports in the core I took a chanse and booted the switch. Now I'm not able to connect to the switch, I am able to just about log in before I loose connection. The admin-port, (ethernet-port) is up for about 30 sec before I loose connection and the routine repeats itself. The switch is Brocade but labeld IBM B32, the current OS is 6.1.1a, I was trying to upgrade to 6.2.2 and then to 6.3.1a.
Is there a way to upgrade the code without the ethernet-port? Any other helpful hints on how to solve this?
Here is the output I'm able to get the seconds I'm logged in.
Fabric OS (IBM_2005_B32)
Fabos Version 6.1.1a
IBM_2005_B32 login: admin
Password:
Broadcast message from root Mon Nov 15 00:00:00 2010...
Notice: System has changed state to active.
All active commands are available now.
Super Contributor
Re: Lost connection with switch during fw-upgrade.
Connectin lost, is most caused by Firewall behind between Switch and FTP Server, or wrong configured IP Address.
an you post here please the exact outptut from "firmwareshow" ?
Anonymous
Hi
The switch was able to download the code from the ftp-server. The same as with the other switches I upgraded that night. The difference is that it had problems implementing the upgrade, thats when I booted the switch. Now I have problems accessing the switch for more than 30 sec before the ethernetport is going down, I do not have the time to run a firmwareshow command before I am thrown out. Something whent wrong during codeupgrade and booting the switch certainly did not help. So I am wondering if there is a way out of this mess?
Anonymous
Here is output from the switch connected via serial cabel. The switch loops with the same messages. What do I have to do to recover this switch?
Any ideas anyone?
Bjørnulf
loading kernel
loaded at:     01000000 01400364
board data at: 013FE324 013FE364
relocated to:  01005110 01005150
zimage at:     0100597D 01172C93
initrd at:     01173000 013FDC00
avail ram:     01401000 10000000
Linux/PPC load:
BootROM command line: quiet
Uncompressing Linux...done.
Now booting the kernel
PCI: Cannot allocate resource region 0 of device 0000:00:00.0
Installing Linux 2.6 Kernel
Attempting to find a root file system on hda1...
INIT: version 2.78 booting
Bypassing firmware validation.
--- Partition /dev/hda2 is inconsistent.
--- Its content will be restored to be the same as that of /dev/hda1.
--- Please check the version and re-load firmware if necessary after the system
boots up.
INIT: Entering runlevel: 3
rls_validate_file_3: 1024 indexes lost
uptime: 4293889640; sysc_qid: 0
2010/11/17-14:17:34, , 1,, INFO, IBM_2005_B32, Processor rebooted - Un
known
IBM_2005_B32 console login: SNMP Research EMANATE/Lite Agent Version 16.2.0.9
Copyright 1989-2006 SNMP Research, Inc.
sysctrld: all services Standby
2010/11/17-14:17:47, , 2,, INFO, FD1_SA_003, The effective configurat
ion has changed to NyGilde.
sec0: Security is initializing........
sysctrld: all services Active
kernel BUG in cache_grow at mm/slab.c:2217!
Oops: Exception in kernel mode, sig: 5
NIP: C0042840 LR: C0042118 SP: CB5D70B0 REGS: cb5d6ff0 TRAP: 0700  DBCR0:4000000
0 Tainted: P
simple_pd_save done!
PowerPC Book-E Watchdog Exception
MSR: 00021000 EE: 0 PR: 0 FP: 0 ME: 1 IR/DR: 00
TASK = cb539bd0 'emd0' THREAD: cb5d4000
Last syscall: 54
GPR00: FFE8800F CB5D70B0 CB539BD0 C031B6C0 C13FF4A0 00000000 0000000C CB5D712C
GPR08: C13FF4B0 00000001 C13FE220 3EC00B60 00200200 1073B86C 00000000 00000007
GPR16: CE8A15E0 CB5D7A98 CB5D7A88 D2CE0000 D2CBC6FC D2CB0000 D2CC0000 D2CC0000
GPR24: 0000000C 000000D1 00000001 C13FF4B0 C13FF4A8 00100100 C031B6C0 C13FE220
NIP cache_alloc_refill+0x244/0x510
LR __kmalloc+0xb4/0xb8
Call trace:
cb5d70e0 __kmalloc+0xb4/0xb8
cb5d70f0 kmalloc_wrapper_dbg+0x4c/0x26c
cb5d7110 condor_dma_instantiate+0xbc/0x288
cb5d7170 condor_chip_instantiate+0x1e8/0x448
cb5d7280 pulsar_chip_create+0x23c/0x554
cb5d7320 blade_hierarchy_instantiate+0xe00/0x172c
cb5d7410 pulsar_inst+0x22c/0x5a4
cb5d74f0 fabsys_blade_instantiate+0x48/0x64
cb5d7510 fabsys_blade_init+0x50/0x47c
cb5d7540 _rdy+0x500/0xf9c
cb5d7630 fsm_controller+0x238/0x2fc
cb5d7670 sys_fsm_dft_ctrl+0x1d4/0x5a4
cb5d7720 slot_dft_class_hndlr+0x70/0xe0
cb5d7770 slot_class_hndlr+0x10c/0x294
cb5d7800 sysScnProcState+0x70/0x14c
cb5d7840 sysCtrlProcCmd+0x4ccc/0x609c
cb5d7ec0 fabsys_ioctl+0x50/0x94
cb5d7ed0 do_ioctl+0x68/0x9c
cb5d7ee0 vfs_ioctl+0xb8/0x400
cb5d7f00 sys_ioctl+0x40/0x74
cb5d7f30 ret_from_syscall+0x0/0x48
hda: task_out_intr: status=0x50 { DriveReady SeekComplete }
ide: failed opcode was: unknown
PD Start
MTRACER
mtracer_panicdump
mtracer_panicdump write=0x3c3b
reboot_reason
set_reboot_reason reason=Software Fault:Kernel Panic
PD_MISC
CONSOLE_LOG
KERNEL_STACK_DUMP
PLATFORM
pl.0
PANIC_DUMP_LOG
PD Time: 14.25745 Seconds
PD Completed
The system is coming up, please wait...
Read board ID of 0x80 from addr 0x23
Read extended model ID of 0x16 from addr 0x22
Matched board/model ID to platform index 4
Checking system RAM - press any key to stop test
Checking memory address: 00100000
System RAM test using Default POST RAM Test succeeded.
Press escape within 4 seconds to enter boot interface.
Booting "Fabric Operating System" image.
loading kernel
Linux/PPC load:
boots up.
pdcheck: info: found new pd: mtd_ts=1290003472 DIE Wed Nov 17 14:17:52 2010, cf_
ts=1290003373
uptime: 4293889785; sysc_qid: 0
2010/11/17-14:18:36, , 3,, INFO, IBM_2005_B32, Processor rebooted - So
IBM_2005_B32 console login: sysctrld: all services Standby
2010/11/17-14:18:47, , 4,, INFO, FD1_SA_003, The effective configurat
NIP: C0042840 LR: C0042118 SP: CB09F0B0 REGS: cb09eff0 TRAP: 0700  DBCR0:4000000
0 Tainted: P
TASK = cb7c34b0 'emd0' THREAD: cb09c000
Last syscall: 54
GPR00: FFE8800F CB09F0B0 CB7C34B0 C031B6C0 C13FF4A0 00000000 0000000C CB09F12C
GPR16: CEF322E0 CB09FA98 CB09FA88 D2CE0000 D2CBC6FC D2CB0000 D2CC0000 D2CC0000
Call trace:
cb09f0e0 __kmalloc+0xb4/0xb8
cb09f0f0 kmalloc_wrapper_dbg+0x4c/0x26c
cb09f110 condor_dma_instantiate+0xbc/0x288
cb09f170 condor_chip_instantiate+0x1e8/0x448
cb09f280 pulsar_chip_create+0x23c/0x554
cb09f320 blade_hierarchy_instantiate+0xe00/0x172c
cb09f410 pulsar_inst+0x22c/0x5a4
cb09f4f0 fabsys_blade_instantiate+0x48/0x64
cb09f510 fabsys_blade_init+0x50/0x47c
cb09f540 _rdy+0x500/0xf9c
cb09f630 fsm_controller+0x238/0x2fc
cb09f670 sys_fsm_dft_ctrl+0x1d4/0x5a4
cb09f720 slot_dft_class_hndlr+0x70/0xe0
cb09f770 slot_class_hndlr+0x10c/0x294
cb09f800 sysScnProcState+0x70/0x14c
cb09f840 sysCtrlProcCmd+0x4ccc/0x609c
cb09fec0 fabsys_ioctl+0x50/0x94
cb09fed0 do_ioctl+0x68/0x9c
cb09fee0 vfs_ioctl+0xb8/0x400
cb09ff00 sys_ioctl+0x40/0x74
cb09ff30 ret_from_syscall+0x0/0x48
PD Start
MTRACER
mtracer_panicdump
mtracer_panicdump write=0x3bcc
reboot_reason
PD_MISC
CONSOLE_LOG
KERNEL_STACK_DUMP
PLATFORM
pl.0
PANIC_DUMP_LOG
PD Time: 14.27619 Seconds
PD Completed
1) Start system.
2) Recover password.
3) Enter command shell.
Option? 1
loading kernel
Linux/PPC load:
boots up.
pdcheck: info: found new pd: mtd_ts=1290003531 DIE Wed Nov 17 14:18:51 2010, cf_
ts=1290003472
uptime: 4293889921; sysc_qid: 0
2010/11/17-14:19:43, , 1,, INFO, IBM_2005_B32, Processor rebooted - Un
known
2010/11/17-14:19:55, , 2,, INFO, FD1_SA_003, The effective configurat
NIP: C0042840 LR: C0042118 SP: CB2CB0B0 REGS: cb2caff0 TRAP: 0700  DBCR0:4000000
0 Tainted: P
TASK = cb160150 'emd0' THREAD: cb2c8000
Last syscall: 54
GPR00: FFE8800F CB2CB0B0 CB160150 C031B6C0 C13FF4A0 00000000 0000000C CB2CB12C
GPR16: CEE443E0 CB2CBA98 CB2CBA88 D2CE0000 D2CBC6FC D2CB0000 D2CC0000 D2CC0000
Call trace:
cb2cb0e0 __kmalloc+0xb4/0xb8
cb2cb0f0 kmalloc_wrapper_dbg+0x4c/0x26c
cb2cb110 condor_dma_instantiate+0xbc/0x288
cb2cb170 condor_chip_instantiate+0x1e8/0x448
cb2cb280 pulsar_chip_create+0x23c/0x554
cb2cb320 blade_hierarchy_instantiate+0xe00/0x172c
cb2cb410 pulsar_inst+0x22c/0x5a4
cb2cb4f0 fabsys_blade_instantiate+0x48/0x64
cb2cb510 fabsys_blade_init+0x50/0x47c
cb2cb540 _rdy+0x500/0xf9c
cb2cb630 fsm_controller+0x238/0x2fc
cb2cb670 sys_fsm_dft_ctrl+0x1d4/0x5a4
cb2cb720 slot_dft_class_hndlr+0x70/0xe0
cb2cb770 slot_class_hndlr+0x10c/0x294
cb2cb800 sysScnProcState+0x70/0x14c
cb2cb840 sysCtrlProcCmd+0x4ccc/0x609c
cb2cbec0 fabsys_ioctl+0x50/0x94
cb2cbed0 do_ioctl+0x68/0x9c
cb2cbee0 vfs_ioctl+0xb8/0x400
cb2cbf00 sys_ioctl+0x40/0x74
cb2cbf30 ret_from_syscall+0x0/0x48
PD Start
MTRACER
mtracer_panicdump
mtracer_panicdump write=0x3c3e
reboot_reason
PD_MISC
CONSOLE_LOG
KERNEL_STACK_DUMP
PLATFORM
pl.0
PANIC_DUMP_LOG
PD Time: 14.26530 Seconds
PD Completed
loading kernel
Linux/PPC load:
boots up.
Anonymous
do you check compact flash usage for this switch before upgrade? you can try to perform supportshow to view this information(bin/df).
if compact flash usage is above 90%, please use savecore  command to clear excess core files.
Super Contributor
--->>>....please use savecore  command
this command is only available and supported by FOS till 5.2.x
In FOS 5.3; and all 6.x is this command not avalable
"supportftp" is supported.
Anonymous
ABBA-SYSTEMS,you are right
bjornulf, i would suggest you try to run this command.
hope this helps.
Anonymous
Hi bjonulf ,
To examine a panic dump file you can run:
pdshow dump_file
...without arguments , it will display the latest dulp file
Based on the messages, you should have one:
PD_MISC
CONSOLE_LOG
KERNEL_STACK_DUMP
PLATFORM
pl.0
PANIC_DUMP_LOG
PD Completed
It might be interesting to see it.
During A firmware upgrade (firmwaredownload) the firmware is downloaded/installed on the secondary partition.
In docs is written(check the firmwareDownload command in FOS Command Reference Manual):
If firmwareDownload is interrupted due to an unexpected reboot as a result of a software error or
power failure, the command automatically recovers the corrupted secondary partition. Wait for the
recovery to complete before starting another firmwareDownload
In your logs is written:
boots up.
Can you run the command:
version
to see which firmware versions do you have on switch ?
If you still see FOS 6.1.1a, you can try to run firmwareRestore
radu.
