Anonymous
Long range SAN connections using SW24000
We need to connect a number of remote servers to Hitachi USP100 storage system. We have two SW24000 with two 16-ports 2 Gb blades each. We have also a pair of iSCSI Gateways in a cluster.
External Moderator
Re: Long range SAN connections using SW24000
Hi, Evgeniy Lotosh!NO! FR4-18i and FC4-18IP are only compatible whit 48000 Chassis.
TechHelp24
External Moderator
Hi, for you convenience, attached both Hardware Reference Manuals for the FR4-18i and FC4-16IP.
TechHelp24
Anonymous
Thank you for help. It seems I need to develop a connection scheme which includes SW7500. At least it is compatible with SW24000. Or risk to use a mixed scheme with Cisco MDS9216 switches.
External Moderator
Hi,-&gt;&gt;&gt; ....All the servers have FC HBAs installed so the simplest way to connect them is to buy a pair of SW4100, buy long range extentions for both SW4100 and SW24000, and connect them directly.<BR> <BR>The best way is, you replaced one 24000 ,whit a new 48000. You can install in the 48K FR4 and FC4 blade, have a better solution and save Money. Only one 7500 is add. requiered for the 24K site, but only if you will Create a Routing at this site, otherview is not necessary.<BR><BR>I'm willing to help by design, please create whit Visio any MAP you SAN Locationa and Post here.<BR><BR>-&gt;&gt;&gt; But other sites are far away (100-200 kilometers),....&lt;!graemlin:;)&gt;Or you have a Little Patience, a new Director would coming surely soon...
TechHelp24
Anonymous
TechHelp24,&lt;!graemlin::)&gt; Maybe we'll implement enother scheme which includes additional low-end storages on remote sites.
