Occasional Contributor
Re: Long Distance Design / Buffer Credits
stat64_wtx     555         top_int : 4-byte words transmitted
               2312858129 bottom_int : 4-byte words transmitted
stat64_wrx     33         top_int : 4-byte words received
               1207217253 bottom_int : 4-byte words received
stat64_ftx     1           top_int : Frames transmitted
               3254182848 bottom_int : Frames transmitted
stat64_frx     0           top_int : Frames received
               3326452805 bottom_int : Frames received
4*2312858129/3254182848=2,8429 this is  absurd low value
on the other hand using the switches graphical interface ports statistics gave following
Out Bytes =
412,21 MB
Out Frames =
495487
OutBytes / Out Frames = bytes/frame
412,21*1024*1024/495487=872,3408
Avg 872,34 bytes -36 bytes overhead = 836 bytes /payload
