Anonymous
License problem
Hello,
I have reset the brocade switch without backing up the license first
I hope I can get some help from you with recovering the license for the switch
The switch model is Silk Worm 3800
P.S
I dont have support
Thanks .
External Moderator
Re: License problem
Start the command supportshow and collect the file.
whit a little luck are the license stored in the file, if no..... Buy a new Switch.
TechHelp24
