Turn on suggestions
Showing results for
11-01-2013 07:50 AM
11-18-2013 08:28 AM
Hi there,
AFAIK, the latest FOS release supported by 200E is v6.2.2f.
When it comes to Brocade 300, this switch supports all the FOS 6.x and 7.x codes.
Rgds,
Felipon
11-18-2013 10:39 AM
felipon, your statement is correct. I went and double checked just to be 100% sure.
