Anonymous
LUNs not showing up directly after reboot
Hi,
External Moderator
Re: LUNs not showing up directly after reboot
Andreas,See here for exact Certification into a Compatibility Matrix.
TechHelp24
Anonymous
Hi,Yes all three switches are running 5.1.0d. HBA-drivers, firmware, OS, are fully supported in the EMC support matrix. I will open up a case on that today.
External Moderator
Andreas,the FC-xxxx and CX-xxx Series Array use a Agent to connect to Host/Server , what i think... use the DMX Series a same procedure also any Agent ? Probable is this not correct configured, and so the LUN's not respond immediately after Server is Reboot ?
TechHelp24
