Occasional Contributor
LSAN require FC router for DCX8510-8 model ?
what is the pre-requities for LSAN configuration ?
Super Contributor
Re: LSAN require FC router for DCX8510-8 model ?
Hello,
for LSAN you have to configure FC-FC routing.
You need to have switch which is supporting FCR.
With DCX8510-8 and proper licenses (virtual fabric license, integraded routing license) you may create virtual router directly on your switch.
Then you have to physically connect default logical switch with base switch with FC cable.
Try to check topic bellow:
https://community.brocade.com/t5/Fibre-Channel-SAN-Forums/FC-to-FC-routing-in-combination-with-San-Extension-using-DCX/td-p/34885
Please mark this response as "Accept as Solution" if it answers your question.
Marian Bezeg
Thanks
we will plan to migrate DCX8510-8 to brocade x6 any documnet to for migration pre-requests ?
And this models support FC-FC routing with out physcial FC router?
how to configure the FC-FC routing for these model switches ?
It  will support LSAN zoning for these models ?
Super Contributor
Hello,
see FAQ for X6 switches:
https://docs.broadcom.com/docs/GA-FAQ-5740-06?eula=true
Yes, X6 is supporting virtual fabrics and FCR routing.
For FCR configruation, you need to have proper background so try to google some information first.
Marian Bezeg
Broadcom Moderator
FC- FC routing including LSAN zone concepts are covered in the FOS admin guide:
http://www2.brocade.com/en/backend-content/pdf-page.html?/content/dam/common/documents/content-types/administration-guide/fos-800-adminguide.pdf
Found in the documents library of my.brocade.com starting on page 475. FC-FC routing and LSAN zones are advanced configuration work, and they should be done by someone with Brocade fabric design credentials, or significant study.
Also, there is a study course that I STRONGLY recommend prior to any routing configuration changes:
https://www.broadcom.com/support/fibre-channel-networking/education/courses/fibre-channel-routing
The entire task of performing FC-FC routing is beyond the scope of the community forum. But - get these two guides, and they will provide all the information you need to do IFL configuration and LSAN zone setup.
doc
Any and all information provided by me is for entertainment value and should not be relied upon as a guaranteed solution or warranty of mechantability. All systems and all networks are different and unique. If you have a concern about data loss, or network disconnection, please open a TAC service request for service through Brocade, or through your OEM equipment provider. If this provided you with a solution to this issue, Please mark it with the button at the bottom "Accept as solution".
External Moderator
[ Edited ]
@rdprrao
--->>>With DCX8510-8 and proper licenses (virtual fabric license....
there is nor VF License available neither required. VF is a Features available on all Gen4 / Gen5 and Gen6 platforms.
is here any technical reason why you want to create FCR and LSAN in order to Migrate from DCX to X6 ?
FCR on Gen6 Platforms with FOS 8.x is mandatory and required only by Old / unsupported in example 4Gb platforms.
to be honest ( saied with caution as I don't know you SAN environments ) I don't see any reason to made such a Migration complicated for such a simple migration.
TechHelp24
