Contributor
Just only one specific F-Port not work fine with few specific F-Ports in its local zone!
[ Edited ]
It might be another strange symptom that the F-Port(JCPMSDB2_BAK) can work fine with its all corresponding zonemembers except for the two good  F-Ports( (JCYKTAPE1;JCYKTAPE3)!
That means JCPMSDB2_BAK can still work fine with JCYKTAPE2 in the same problemtic JCPMSDB2_TapeZone,  and also JCYKTAPE1/3 can  work fine with all other corresponding zones!
Notes: all the corresponding zones with JCPMSDB2_BAK and JCYKTAPE<n> use the HARD WWN addressing schema,and also they are all right from fcping with each other !
CMSFZSAN02:admin>
CMSFZSAN02:admin>
CMSFZSAN02:admin>
CMSFZSAN02:admin> zoneshow JCPMSDB2_37DS5020
 zone:  JCPMSDB2_37DS5020
                PMS2VTape2_WWN; PMS2VTL; JCPMSDB2_BAK
CMSFZSAN02:admin>
CMSFZSAN02:admin>
CMSFZSAN02:admin>
CMSFZSAN02:admin> zoneshow JCPMSDB2_TapeZone
 zone:  JCPMSDB2_TapeZone
                JCPMSDB2_BAK; JCYKTAPE1; JCYKTAPE2; JCYKTAPE3
CMSFZSAN02:admin>
CMSFZSAN02:admin>
CMSFZSAN02:admin>
CMSFZSAN02:​admin> zoneshow JCPMSDB1_TapeZone
 zone:  JCPMSDB1_TapeZone
                JCPMSDB1_BAK; JCYKTAPE1; JCYKTAPE2; JCYKTAPE3
CMSFZSAN02:admin>
CMSFZSAN02:admin>
CMSFZSAN02:admin>
CMSFZSAN02:admin>
CMSFZSAN02:admin> fcping 10:00:00:00:c9:83:a1:18  50:03:08:c0:02:40:18:18
Source:         10:00:00:00:c9:83:a1:18
Destination:    50:03:08:c0:02:40:18:18
Zone Check:     Zoned
Pinging 10:00:00:00:c9:83:a1:18 [0x01ed00] with 12 bytes of data:
received reply from 10:00:00:00:c9:83:a1:18: 12 bytes time:317 usec
received reply from 10:00:00:00:c9:83:a1:18: 12 bytes time:204 usec
received reply from 10:00:00:00:c9:83:a1:18: 12 bytes time:202 usec
received reply from 10:00:00:00:c9:83:a1:18: 12 bytes time:200 usec
received reply from 10:00:00:00:c9:83:a1:18: 12 bytes time:218 usec
5 frames sent, 5 frames received, 0 frames rejected, 0 frames timeout
Round-trip min/avg/max = 200/228/317 usec
Pinging 50:03:08:c0:02:40:18:18 [0x01dd00] with 12 bytes of data:
received reply from 50:03:08:c0:02:40:18:18: 12 bytes time:231 usec
received reply from 50:03:08:c0:02:40:18:18: 12 bytes time:688 usec
received reply from 50:03:08:c0:02:40:18:18: 12 bytes time:227 usec
received reply from 50:03:08:c0:02:40:18:18: 12 bytes time:217 usec
received reply from 50:03:08:c0:02:40:18:18: 12 bytes time:232 usec
Round-trip min/avg/max = 217/319/688 usec
CMSFZSAN02:admin>
CMSFZSAN02:admin>
CMSFZSAN02:admin>
CMSFZSAN02:admin> fcping 10:00:00:00:c9:83:a1:18  50:03:08:c0:02:40:18:03
Destination:    50:03:08:c0:02:40:18:03
Zone Check:     Zoned
received reply from 10:00:00:00:c9:83:a1:18: 12 bytes time:313 usec
received reply from 10:00:00:00:c9:83:a1:18: 12 bytes time:207 usec
received reply from 10:00:00:00:c9:83:a1:18: 12 bytes time:216 usec
Round-trip min/avg/max = 202/228/313 usec
Pinging 50:03:08:c0:02:40:18:03 [0x01df00] with 12 bytes of data:
received reply from 50:03:08:c0:02:40:18:03: 12 bytes time:725 usec
received reply from 50:03:08:c0:02:40:18:03: 12 bytes time:227 usec
received reply from 50:03:08:c0:02:40:18:03: 12 bytes time:215 usec
received reply from 50:03:08:c0:02:40:18:03: 12 bytes time:229 usec
Round-trip min/avg/max = 215/322/725 usec
CMSFZSAN02:admin>
CMSFZSAN02:admin>
CMSFZSAN02:admin>
