Anonymous
Issues on ISL Between Mcdata DS4700 and Brocade DS5100
Hi,
I ISL between Mcdata4700 (firmware: 09.01.00.50) and Brocade 5100 (FOSv6.1.0j). I knew the Mcdata fabric OS is little old but to upgrade firmware we required downtime to do so...Do I need to make any change on the Brocade Interopmode? I couldn't get outage on Mcdata production switch.
Mcdata are on interopmode: Open Fabric 1.0 (DID: 1) and Brocade are on interopmode: McData Fabric Mode. (DID:99)
Please let me know if there is any way to configure brocade (new switch) to ISL with the Mcdata..
I've done the similar configured on the different site last month  and its working fine.. they are also (DS4700 ISL DS5100) but the McData firmware version on 9.02.00.8. See the following thread -  http://community.brocade.com/home/thread/3917
switch03:admin> switchshow
switchName:     switch03
switchType:     66.1
switchState:    Online
switchMode:     McDATA Open Fabric
switchRole:     Principal
switchDomain:   99
switchId:       fffc63
switchWwn:      10:00:00:05:1e:bb:61:bb
zoning:         OFF
switchBeacon:   OFF
FC Router:      OFF
FC Router BB Fabric ID: 1
Area Port Media Speed State     Proto
  0   0   id    N8   No_Sync          Disabled (Persistent)
  1   1   id    N4   No_Light
  2   2   id    N4   No_Light
  3   3   id    N4   No_Light
  4   4   id    N4   No_Light
  5   5   id    N4   No_Light
  6   6   id    N4   No_Light
  7   7   id    N4   No_Light
  8   8   id    N4   No_Light
  9   9   id    N4   No_Light
10  10   id    N4   No_Light
11  11   id    N4   No_Light
12  12   id    N4   No_Light
13  13   id    N4   No_Light
14  14   id    N4   No_Light
15  15   id    N4   No_Light
16  16   id    1G   Online           E-Port  segmented,(Security Violation)
17  17   id    N4   No_Light
18  18   id    N4   No_Light
19  19   id    N4   No_Light
20  20   id    N4   No_Light
21  21   id    N4   No_Light
22  22   id    N4   No_Light
23  23   id    N4   No_Light
24  24   --    N8   No_Module        (No POD License) Disabled
25  25   --    N8   No_Module        (No POD License) Disabled
26  26   --    N8   No_Module        (No POD License) Disabled
27  27   --    N8   No_Module        (No POD License) Disabled
28  28   --    N8   No_Module        (No POD License) Disabled
29  29   --    N8   No_Module        (No POD License) Disabled
30  30   --    N8   No_Module        (No POD License) Disabled
31  31   --    N8   No_Module        (No POD License) Disabled
32  32   --    N8   No_Module        (No POD License) Disabled
33  33   --    N8   No_Module        (No POD License) Disabled
34  34   --    N8   No_Module        (No POD License) Disabled
35  35   --    N8   No_Module        (No POD License) Disabled
36  36   --    N8   No_Module        (No POD License) Disabled
37  37   --    N8   No_Module        (No POD License) Disabled
38  38   --    N8   No_Module        (No POD License) Disabled
39  39   --    N8   No_Module        (No POD License) Disabled
switch03:admin> fabstatsshow
Description                      Count
Domain ID forcibly changed:          0
E_Port offline transitions:          0
Reconfigurations:                    0
Segmentations due to:
                  Loopback:          0
           Incompatibility:          0
                   Overlap:          0
                    Zoning:          0
            E_Port Segment:          0
                 Licensing:          0
           Disabled E_Port:          0
               Platform DB:          0
       Sec Incompatibility:          0
             Sec Violation:          1 <
                 ECP Error:          0
             Duplicate WWN:          0
  Eport IsolatedAD header conflict:          0
Thanks.
Chin
External Moderator
Re: Issues on ISL Between Mcdata DS4700 and Brocade DS5100
FOS 6.1.x cannot operate whit EOS 09.01.xx or 09.02.xx
You must first Upgrade the McDATA to EOS 09.06.02 or higher in order to operate with FabricOS.
It is highly recommended that M-EOS products operate with the most recent version of M-EOS
released and supported for interoperability. M-EOS 9.6.2 is the minimum version of firmware that
can be used to interoperate with FOS 6.1.0 or later. M-EOS 9.7 or later is recommended for optimum
fabric performance in a mixed FOS and M-EOS fabric.
TechHelp24
External Moderator
About the Security violation When you are in McDATA mode.
--->>> 16  16   id    1G   Online           E-Port  segmented,(Security Violation)
2: to turn McDATA Fabric mode on
Valid McDATADefaultZone: 0 (disabled), 1 (enabled)
Valid McDATASafeZone: 0 (disabled), 1 (enabled)
Use the "interopmode" command to verify is the Default/Save zone is correct set.
To verify is the Fabric is stable, use the command "fabricshow",
In order to enabling or disabling safezoning or default zoning, use the command "cfgmcdtmode"
For Operands details refer please the CLI manual.
with command "interopmode --show" can you list the current mode is set.
If the McDATA is set in safe zone mode ( as default ) you ned to enable safe zoning in IM2.
Why is the Port is set as 1G ?
If you use in Brocade 5100 8G SFP, this cannot Operate as 1G
try "sfpshow -all" post the result here please.
Are you sure the McDATA is 4700 ? this is 4G Switch, which sense make  Ito SL's a 4G Switch to 5100 ans set as 1G ?
TechHelp24
External Moderator
You wrote here.
--->>> Mcdata are on interopmode: Open Fabric 1.0 (DID: 1) and Brocade are on interopmode: McData Fabric Mode. (DID:99)
Output from switchshow, show as follow:
switchType:     66.1
switchState:    Online
this is a bit confused, is the Brocade according switchshow o/p current set as IM3= McDATA Open Fabric or as IM2= McDATA Fabric Mode ?
TechHelp24
Anonymous
Hi TechHelp24,
In fact, it was on "Auto" speed but I just try to use 1G or set to 4G but it doesnt help to resolve the problem.
I've now change it back to Auto, but problem still persistent. Here is the output of "sfpshow -all".
switch03:admin> sfpshow -all
Port  0:
port 0: can't get serial data
Port  1:
Identifier:  3    SFP
Connector:   7    LC
Transceiver: 150c402000000000 100,200,400_MB/s M5,M6 sw Inter_dist
Encoding:    1    8B10B
Baud Rate:   43   (units 100 megabaud)
Length 9u:   0    (units km)
Length 9u:   0    (units 100 meters)
Length 50u:  15   (units 10 meters)
Length 62.5u:7    (units 10 meters)
Length Cu:   0    (units 1 meter)
Vendor Name: BROCADE
Vendor OUI:  00:05:1e
Vendor PN:   57-1000013-01
Vendor Rev:  A
Wavelength:  850  (units nm)
Options:     001a Loss_of_Sig,Tx_Fault,Tx_Disable
BR Max:      0
BR Min:      0
Serial No:   WAA109304501592
Date Code:   090724
Temperature: 36 Centigrade
Current:     5.300 mAmps
Voltage:     3324.4 mVolts
RX Power:    -inf  dBm (0.0 uWatts)
TX Power:    -3.5  dBm (448.5 uWatts)
Port  2:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501596
Date Code:   090724
Temperature: 37 Centigrade
Current:     4.944 mAmps
Voltage:     3322.2 mVolts
TX Power:    -3.9  dBm (406.4 uWatts)
Port  3:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501587
Date Code:   090724
Current:     5.024 mAmps
Voltage:     3322.5 mVolts
TX Power:    -4.1  dBm (390.0 uWatts)
Port  4:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501594
Date Code:   090724
Temperature: 34 Centigrade
Current:     5.820 mAmps
Voltage:     3320.6 mVolts
TX Power:    -5.4  dBm (291.6 uWatts)
Port  5:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501580
Date Code:   090724
Temperature: 33 Centigrade
Current:     4.926 mAmps
TX Power:    -4.0  dBm (396.0 uWatts)
Port  6:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501597
Date Code:   090724
Temperature: 35 Centigrade
Current:     5.748 mAmps
Voltage:     3300.9 mVolts
TX Power:    -5.9  dBm (258.8 uWatts)
Port  7:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501590
Date Code:   090724
Current:     4.934 mAmps
Voltage:     3324.1 mVolts
TX Power:    -4.3  dBm (372.8 uWatts)
Port  8:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501605
Date Code:   090724
Current:     5.128 mAmps
Voltage:     3301.3 mVolts
TX Power:    -3.8  dBm (412.3 uWatts)
Port  9:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501612
Date Code:   090724
Current:     5.554 mAmps
Voltage:     3303.3 mVolts
TX Power:    -4.3  dBm (369.6 uWatts)
Port 10:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501582
Date Code:   090724
Current:     5.370 mAmps
Voltage:     3303.8 mVolts
TX Power:    -3.6  dBm (438.2 uWatts)
Port 11:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501617
Date Code:   090724
Current:     5.186 mAmps
Voltage:     3324.3 mVolts
TX Power:    -4.9  dBm (323.4 uWatts)
Port 12:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501598
Date Code:   090724
Current:     4.726 mAmps
Voltage:     3291.4 mVolts
TX Power:    -4.3  dBm (372.9 uWatts)
Port 13:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501595
Date Code:   090724
Current:     5.486 mAmps
Voltage:     3288.8 mVolts
TX Power:    -4.3  dBm (372.4 uWatts)
Port 14:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501586
Date Code:   090724
Current:     5.196 mAmps
Voltage:     3322.7 mVolts
TX Power:    -3.7  dBm (427.8 uWatts)
Port 15:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   WAA109304501609
Date Code:   090724
Temperature: 38 Centigrade
Current:     5.326 mAmps
Voltage:     3291.9 mVolts
TX Power:    -3.6  dBm (438.6 uWatts)
Port 16:
Identifier:  3    SFP
Connector:   7    LC
Transceiver: 150c402001000000 100,200,400_MB/s M5,M6 sw Inter_dist
Encoding:    1    8B10B
Baud Rate:   42   (units 100 megabaud)
Vendor Rev:  A
Options:     0032 Loss_of_Sig,Tx_Disable
BR Max:      0
BR Min:      0
Serial No:   VAF209260000G5M
Date Code:   090623
Temperature: 27 Centigrade
Current:     7.398 mAmps
Voltage:     3286.2 mVolts
RX Power:    -4.2  dBm (384.2 uWatts)
TX Power:    -4.6  dBm (348.8 uWatts)
Port 17:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   VAF2092700000NR
Date Code:   090630
Current:     6.798 mAmps
Voltage:     3302.7 mVolts
TX Power:    -4.6  dBm (349.2 uWatts)
Port 18:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   VAF209260000G5C
Date Code:   090623
Temperature: 40 Centigrade
Current:     7.470 mAmps
Voltage:     3280.9 mVolts
RX Power:    -31.5  dBm (0.7 uWatts)
TX Power:    -4.6  dBm (343.4 uWatts)
Port 19:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   VAF20927000014L
Date Code:   090630
Current:     7.596 mAmps
Voltage:     3300.6 mVolts
TX Power:    -4.6  dBm (344.9 uWatts)
Port 20:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   VAF20927000014N
Date Code:   090630
Current:     6.916 mAmps
Voltage:     3310.8 mVolts
TX Power:    -4.5  dBm (351.3 uWatts)
Port 21:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   VAF209260000K7C
Date Code:   090624
Current:     7.040 mAmps
Voltage:     3291.7 mVolts
TX Power:    -4.6  dBm (343.7 uWatts)
Port 22:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   VAF209260000K5Y
Date Code:   090624
Temperature: 31 Centigrade
Current:     7.902 mAmps
Voltage:     3285.4 mVolts
TX Power:    -4.6  dBm (345.1 uWatts)
Port 23:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   VAF209260000K8F
Date Code:   090624
Current:     7.420 mAmps
Voltage:     3295.4 mVolts
TX Power:    -4.6  dBm (348.9 uWatts)
Port 24:
port 24: can't get serial data
Port 25:
port 25: can't get serial data
Port 26:
port 26: can't get serial data
Port 27:
port 27: can't get serial data
Port 28:
port 28: can't get serial data
Port 29:
port 29: can't get serial data
Port 30:
port 30: can't get serial data
Port 31:
port 31: can't get serial data
Port 32:
port 32: can't get serial data
Port 33:
port 33: can't get serial data
Port 34:
port 34: can't get serial data
Port 35:
port 35: can't get serial data
Port 36:
port 36: can't get serial data
Port 37:
port 37: can't get serial data
Port 38:
=============nmumsansw03:cng50> sfpshow -all
Port  0:
Port  1:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port  2:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port  3:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port  4:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port  5:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port  6:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port  7:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port  8:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port  9:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port 10:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port 11:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port 12:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port 13:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port 14:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port 15:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090724
Port 16:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090623
Port 17:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090630
Port 18:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090623
Port 19:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090630
Port 20:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090630
Port 21:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090624
Port 22:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090624
Port 23:
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Date Code:   090624
Port 24:
Port 25:
Port 26:
Port 27:
Port 28:
Port 29:
Port 30:
Port 31:
Port 32:
Port 33:
Port 34:
Port 35:
Port 36:
Port 37:
Port 38:
port 38: can't get serial data
Port 39:
port 39: can't get serial data
nmumsansw03:cng50>
Port 39:
switch03:admin>
Anonymous
Hi,
Sorry to confusing you, my apologies for the wrong info. The interopmode on Brocade are currently set to "McDATA Open Fabric" (Option 3).
switch03:admin> interopmode
InteropMode: McDATA Open Fabric
usage: InteropMode ]
       0: to turn interopMode off
           Valid McDataDefaultZone: 0 (disabled), 1 (enabled)
           Valid McDataSafeZone: 0 (disabled), 1 (enabled)
      3: to turn McDATA Open Fabric mode on
Thanks.
Chin
External Moderator
Chin,
as mentioned....
1. Apr 11, 2010 9:12 PM in response to: chinseong.ng
But... are you sure the 4700 is correct set ? can you check please the event log in the EFCM GUI from 4700 ?
--->>> Sorry to confusing you, my apologies for the wrong info. The interopmode on Brocade are currently set to "McDATA Open Fabric" (Option 3).
About McDATADefaultZone and McDATASafeZone this don't have any impact in your config, because are not supported in IM3
TechHelp24
Anonymous
Hi TechHelp24,
This issues has been resolved, the problem was on McData 4700... There is some setting turn on on McData 4700, after we turn it off and the ISL is working fine now. I've done this on DCFM GUI.. under the Security -> uncheck the checkbox on  "Safe Zoning Mode".
As always, we should upgrade the firmware to the latest supported version. So we will schedule for the firmware upgrade on next available maintenance window.
Thank you for your support.
Chin.
