Turn on suggestions
Showing results for
12-21-2017 08:50 AM - edited 12-21-2017 08:53 AM
MSG: Parameter / SAN_SWITCH_IO_THROUGHPUT / SAN_SWITCH_IO_THROUGHPUT / PatrolStatus is in CRITICAL . Value is: 1.00
MSG Long:
Number error in this line :problem connecting to store-sw-21, port 23: connect timed-out at /pkg/vdc9i/patrol/scripts.D/SAN_SWITCH_IO_THROUGHPUT.D/porterrshow.pl line 11 => tx = 1000000 ... rx = .
origin: deapvi9i.com:3183
objectClass: _SAN_SWITCH_IO_THROUGHPUT
object: _SAN_SWITCH_IO_THROUGHPUT
parameter: PatrolStatus
cluster: MONITORING
prio: 3
assignment: AS-MONITORING-2ND
servicetime: 1
Event Time: 20171215092225.000000+060
