New Contributor
Issue about HFBR-57E0ALZ
1. Does this SFP module - HFBR-57E0ALZ can work normally without using EEPROM interface, in another word, does the SFP module need to configured before it can works?
  1. What is the EEPROM address for the I2C interface, is it read only or not?
  2. How about the SFP AFCT-5705Z?  I have the same two questions as above.
External Moderator
Re: Issue about HFBR-57E0ALZ
@will.cui
where you want to use those SFP's ?
Switch Type ? FOS Release ?
apart on that, since Gen4 Switches only genuine Labelled Brocade SFP are supported and certified, excepted WDM SFP.
TechHelp24
New Contributor
Hi, we don't use the Switch,  the SFP is installed on our module,  the communication is point to point .
My question is "do we need to configure the SFP module using I2C interface?  If yes,  what's the I2C device address for these modules? "
External Moderator
@will.cui
you are here with you question totally wrong, this community support FC Switches and it's related SFP.
And I don't know what kind for module you talk about.
TechHelp24
