Anonymous
Isl'ing brocade to McData Switches
I am attempting to ISL a Brocade 2800 to a Mcdata Switch and wondering if somebody can give me the Do’s and Don’ts. The errors that I have encountered include the following:
Anonymous
Re: Isl'ing brocade to McData Switches
Make sure your 2800 is in interoperability mode...
Anonymous
Do you have procedures to put switch into interoperability mode?
Anonymous
I believe that you just have to plug it into another vendors switch and it should automatically go into interop mode. I attached a Brocade Whitepaper on interoperability for you. It's old, but maybe it'll help.I'll ask around for any procedures.
Anonymous
To put the Brocade switch in interop mode you should do the following:You're done.
Anonymous
You must also put de McData switch into interop mode.HTH
Anonymous
I found that when I used McData Fabric mode I was able to use the Brocade to manage Aliases and Zones.
If I used Open Fabric then I had to manage the Zones on the McData and no Aliases.
