New Contributor
Accepted Solution
Is it possible to make a ICL connection from DCX4 to 8510?
Hi
is it possible to connect by ICL cables a DCX4 to an 8510?
The connectors are different between the two stuff so I think I can do this by ISL
Thx
Walter
External Moderator
Re: Is it possible to make a ICL connection from DCX4 to 8510?
you cannot ICL between old DCX / DCX-4S to DCX-8510 Series
ICL between DCX-8510 to new Gen6 X6 is compatible
TechHelp24
