Anonymous
Is it possible to create a tunnel between 7500M and 7800M SAN Routers? OS - 6.3.0b
Hi,
Thanks,
Anonymous
Re: Is it possible to create a tunnel between 7500M and 7800M SAN Routers? OS - 6.3.0b
Hi,
No it is not possible to connect these two systems via fcip as they don't "speak " the same language .
Regards
Rene
External Moderator
Hi vikas.jain,
please see below and attached PDF.
If you are satisfied with the responses please mark as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
Thank you.
Do the Brocade FX8-24 and Brocade 7800 interoperate with other Fabric OS
A The Brocade FX8-24 and Brocade 7800 utilize the same Fabric OS that supports the entire Brocade SAN product family—from the 8-port Brocade 300 Switch to the 768-port Brocade DCX Backbone. This helps ensure seamless interoperability with optional advanced features such as ISL Trunking, Advanced Performance Monitoring, Fabric Watch, and Advanced Zoning.
® switches?
Although the Brocade FX8-24 and Brocade 7800 are compatible with current and previous-generation Fibre Channel switches, they do not support FCIP connectivity with other extension products, including the Brocade FR4-18i or Brocade 7500/7500E
TechHelp24
