Anonymous
Is installing a 48 port blade in Brocade DCX8510 non-dirusptive?
Is installing a 48 port blade in Brocade DCX8510 non-dirusptive? What precautions should be taken?
Valued Contributor
Re: Is installing a 48 port blade in Brocade DCX8510 non-dirusptive?
hi,
yes it is non-disruptive.
just read the procedure available in the switch hardware guide.
rgds
Frequent Contributor
The 8510 Hardware Reference Manual referenced above can be found here:
(Replacing a Blade)
http://www.brocade.com/downloads/documents/html_product_manuals/DCX_8510_8_HRM_07/GUID-3420C9D9-B0E8-400B-A134-F8752ECA114A.html
I' m not sure what your 8510 configuration is, but you should also take a look at the release notes for the firmware you are runniing.
Specifically the sections below:
"Typical Power Supply Requirements Guidelines for Blades in DCX 8510"
"DCX 8510-8/DCX 8510-4 Blade Support Matrix"
Cheers,
-Bill
Valued Contributor
just check for the loose screws on the new blade before inserting it ;)
Anonymous
Thanks!
