Anonymous
Interopmode issue with McDATA switch
I have configured Brocade switch with interopmode 2 to migrate McDATA (McDATA Fabric mode)...
I am getting E-port segmented with zone conflict message on Brocade
LabSGP:FID128:admin> switchshow
switchName:     LabSGP
switchType:     66.1
switchState:    Online
switchMode:     McDATA Fabric
switchRole:     Principal
DomainIDOffset: 0x60
switchDomain:   4
switchId:       fffc24
switchWwn:      10:00:00:05:1e:0f:6c:9f
zoning:         OFF
switchBeacon:   OFF
FC Router:      OFF
Allow XISL Use: OFF
LS Attributes:
Index Port Address Media Speed State     Proto
  0   0   640000 id    N8   No_Light    FC
  1   1   640100 id    N8   No_Light    FC
  2   2   640200 id    N8   No_Light    FC
  3   3   640300 id    N8   No_Light    FC
  4   4   640400 id    N8   No_Light    FC
  5   5   640500   id N8   No_Light    FC
  6   6   640600 id    N8   No_Light    FC
  7   7   640700 id    N8   No_Light    FC
  8   8   640800 id    N8   No_Light    FC
  9   9   640900 id    N8   No_Light    FC
10  10   640a00   id N8   No_Light    FC
11  11   640b00   id N8   No_Light    FC
12  12   640c00   id N8   No_Light    FC
13  13   640d00   id N8   No_Light    FC
14  14   640e00   id N8   No_Light    FC
15  15   640f00   id N1   Online      FC  E-Port segmented,(zone conflict)
Prior to change of interopmode I have done cfgdisable, cfgclear, cfgsave at brocade, configured IM 2 with safe zone ON.
Brocade FOS : v6.4.3d , McDATA is on Firmware Version: 09.08.01
please suggest...
External Moderator
Re: Interopmode issue with McDATA switch
"cfgmcdtmode" command, can you verify if McDATA Config mode is enable or disable.
Additional, i see in switchshow output, the segmented port is set as N1, keep in mind 8G SFP+ not support 1GB FC.
If you have in McDATA Switch 1Gbits SFP, the you must use is 5100 a 4G SFP
TechHelp24
