Anonymous
Interop mode 3 between Brocade 5000 and cisco MDS switch :propagation Zone Fail
hello
i have 2 fabrics with for each one a DS5000 ( Brocade OEM) 16 port and CISCO MDS switch for Ibm blade center.
With FOS 6.01a for the 5000B who is the principal and SAN OS 3.1(3a) for the Cisco, i use the Interope Mode 3 on the cisco, so my DS5000 is not altered ( core PID enabled)
When i create or change my config zone on the DS5000, there is not propagation to the cisco !
if i make a "shut/no shut" for the ISL port on the cisco ( ext0) i have this message
PORT-5-IF_DOWN_ZONE_MERGE_FAILURE_ISOLATION: %$VSAN 1%$ Interface ext0 is down (Isolation due to zone merge failure
after i enable the port with "zone merge interface ext0 import vsan 1" and i get a correct new zoneset ..
but i can not stop my fabric for besure to propagate a zone change on my principal swith
someone has an idea ?
thanks
Pascal
External Moderator
Re: Interop mode 3 between Brocade 5000 and cisco MDS switch :propagation Zone Fail
Pascal,
i have my doubt that SAN-OS rel 3.1.x work with FOS 6.x
Only FabOS v5.3.0b is Certified by Cisco with SAN-OS 3.2.x and 3.3.x
Interop Matrix is Attached.
TechHelp24
TechHelp24
Anonymous
Hi
i check this file . so i can not find my Brocade Switch Model ( 5000) but, wihtout take this, i have the SAN OS 3.1 (3a) version ( i think to upgrade) and for FOS 5.3.0b we need what you tell, SAN OS 3.2.x and 3.3.x ..
and i don't have..
Interop Matrix from EMC ( OEM brocade) and Cisco are not the same !!
thank you ..
