Anonymous
Re: Inter-Chassis-Links (ICL)
I read through the document, part 11; it is very helpful yet it does not clearly answer my question.
I need to confirm that I can use 2 ICL ports in one user defined logical switch and the other 2 ICL ports in another user defined logical switch. Thus, having separate ISL trunks for each virtual fabric (i.e. in order to give each VF a dedicated bandwidth)?
Anonymous
I have already written yes, but also it depends upon the licenses, you buy. So the best way is while buying licenses, discuss with your SW vendor and also first let them know ur requirements. They are the best people who can help you at any time.Best of luck
