Anonymous
Installing CTP card in M6140 Director
Can I install a new CTP card in our M6140 director without powering it down? I can't find the power switch.
External Moderator
Re: Installing CTP card in M6140 Director
--->>>  I can't find the power switch.
I believe the 6140 dont have a power switch. The Director Power is On when you Plug the Power Cord.
Only the 6064 have a Power On/Off switch
Not sure, i work last with 6140 appr. 5 Years ago.
--->>> Can I install a new CTP card in our M6140 director without powering it down?
Yes, all Part SBAR, FAN, Power Supply, Port Card and CTP can be replaced w/o shutdown.
By CTP Replacement, make sure the Standby CTP is runing and Active
When you remove the failed CTP wait 20-30 Second before insert the Replacement CTP board
TechHelp24
External Moderator
btw, you are in the wrong forum Community Info and Feedback
please post at next time similary question in the correct forum
Products, Technology, and Architecture
thank you
TechHelp24
Anonymous
THANK YOU for your assistance. It confirmed my observation that there is no power switch for M6140.
