Turn on suggestions
Showing results for
08-08-2010 03:29 PM
Hi,
I would like to change the Port speed from N4 (Negotiable) to 4Gb fixed in the brocade switch(Brocade 5000 series) where EVA storage controller ports are connected.
But all these EVA storage controller ports are member of one or more active zones. So changing the port speed will obviously results in path failure in zoned servers.
Can anyone kindly suggest how to change the port speed with out any/minimal impact on production servers
Please revert back if more information required. Thanks for your understanding..
Regards,
Arun
08-08-2010 08:27 PM
--->>>> I would like to change the Port speed from N4 (Negotiable) to 4Gb fixed...
4G is the default Speed by Brocade 5000.
Try a command "portcfgspeed" with operand
i.e.
portnumber = 5
speed = 4
"portcfgspeed 5 4"
--->>> Can anyone kindly suggest how to change the port speed with out any/minimal impact on production servers
Note: This command disable and enable the Port you select and is for short time disruptive,
08-10-2010 09:43 AM
if EVA controller prots are 4 Gbps , you do not need to change it.
