Anonymous
ISL compatibility between BES-5832B and McData 4500
Hi,
We are in the process of SAN consalidation, planning to ISL our existing McData 4500 2G 24 Ports SAN switch with Brocade Encription Switch ES-5832B 8G 32Ports.  Are there any limitations or compatibility issues?
Regards
Raj
External Moderator
Re: ISL compatibility between BES-5832B and McData 4500
--->>> Are there any limitations or compatibility issues?
AFAIK,
McDATA 4500 and all old 2G McDATA ( excepted 6140 ) are not supported with Brocade Encryption SAN Switch.
If you are satisfied with the responses please mark as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
Thank you.
TechHelp24
