Anonymous
ISL between brocade 5300 and 4100
I want to build a fabric ISL between brocade 5300 (core) & 4100 (edge).
To make sure that I will work, below my questions:
1/ taking 2 opposite (non_consecutive) quad card, I will get 2 trunk group ?
2/ What are the best practices in terms on physical connexions : 1 trunk with 8 consecutive port or 2 trunks with 4 consecutive ports ?
3/ Do I need to set all the ports to Auto or 4 giga ?
4/ I might need to connect a switch McData to build a fabric with Brocade.
What are the requirements and cli commands to do that ?
I know that between 2 brocades, steps will be :
- switchdisable
- Set Domain ID
- connect ISL
- switch Enabe
5/ Is the a new documentation on how to design SAN between Brocade switchs, beween McData switchs, between Brocade and McData switch?
Thank you for your help
External Moderator
Re: ISL between brocade 5300 and 4100
ramses,
-> 2/ What are the best practices in terms on physical connexions : 1 trunk with 8 consecutive port or 2 trunks with 4 consecutive ports ?
I would you recommended to 1 Trunk 4 Port, to avoid a config mistmach
-> 4/ I might need to connect a switch McData to build a fabric with Brocade.
McDATA and Brocade can only operate in IM 2 or 3, please note that some feature are not longer supported by FabOS if is the Mode is changed.
Details are listet in the release notes.
-> 5/ Is the a new documentation on how to design SAN between Brocade switchs, beween McData switchs, between Brocade and McData switch?
A general DOC is not available, See the FabOS Admin Guide
TechHelp24
TechHelp24
Anonymous
thank you.
Another questions regarding fabrc configuration between brocade 5300 (core) and brocade 5100 (edge) :
1/ Can I use 8 giga sfp and force full duplex for ISL link ?
2/ You advice using 4 ports in one trunk. since te the trunk is one a quad card if this card fail, you will lose all the connexions. So, I might be better to use 2 trunks of 2 ISL instead of 1 trunk of for ISL ?
3/ Using to trunks is it better to use the 2 opposite card quad instead or two close card quad ?
3/ What is generally configured for the non isl ports on edge switchs (servers connexion) : autonegotiate, 2, 4 ?
