Anonymous
ISL between Brocade and Cisco MDS 9148 FC Switch
Dear All,
We have Brocade FC Switch (HP B-series 8/24c SAN Switch)
HICHPFCSW1:admin> switchshow
switchName:     HICHPFCSW1
switchType:     72.3
switchState:    Online
switchMode:     Native
switchRole:     Principal
switchDomain:   103
switchId:       fffc67
switchWwn:      10:00:00:05:33:bf:81:8c
zoning:         OFF
switchBeacon:   OFF
We also have Cisco MDS 9148 FC Switch.
We want to ISL these two switches.
We have storage connected on Cisco Switches, we want to make it available to Brocade Switchs.
We have put the fibre cables between two switches.
We want to know how we can proceed with the same?
Thanks,
Ashish K
Message was edited by: Ashish Kesarkar
Anonymous
Re: ISL between Brocade and Cisco MDS 9148 FC Switch
Hi,
one way would be to enable "Access Gateway" on the Brocade HP-Class 8/24c switch.
You would then need to do all the zoning and configuration on the Cisco-switch.
There is a good and extensive "Access Gateway Administrator's Guide" about that.
You could also enable NPV on the Cisco-switch (and use the Brocade switches as the master).
You could use interopmode, but this is not supported in Fabric OS 7: http://community.brocade.com/docs/DOC-2639
Valued Contributor
Hi,
All the options mentioned by Guldmyr are ok, but among them I recommed you to config the Brocade switchs as "Access Gateway" devices: it would be the less disruptive and faster way to connect those Brocades.
