Anonymous
ISL between Brocade 300 and Brocade DCX
Hi Guys ,
I have an urgent activity ,I need to connect Brocade 300 to Brocade DCX in the building and the distance is 30 meter .
Is there any step by step guide available .
BR
Anonymous
Re: ISL between Brocade 300 and Brocade DCX
Both are online and have Zone active
External Moderator
you cannot ISL TWO Switch with Different config name and different zoning/alias.
when you do that ISL get segmented
TechHelp24
Anonymous
Thanks for your comment , but as I read , there is a way to connect them all and merge the zones !!
External Moderator
is a bit complexed, and as mentioned, you cannot ISL TWO Switch with different config
TechHelp24
Anonymous
not even  a disruptive/offline way if he is ok with it? Or are you saying those two types cannot go together?
External Moderator
mohammad akkoub wrote:
--->>>Both are online and have Zone active
main question:
-have both switch different Domain ID ?
-Compatible FOS ?
-same identically config ?
TechHelp24
External Moderator
mohammad,
show here, maybe can help you to understand how to merge
How to merge two Brocade fabrics - NetworkAdminKB.com
TechHelp24
Former Brocadian
In addition to TechHelp24's guide, you may wish to review the following link for zone merging out of the FOS Admin Guide:
http://www.brocade.com/downloads/documents/html_product_manuals/FOS_AG_710/wwhelp/wwhimpl/js/html/wwhelp.htm#href=zone.17.13.html
areas to review:
1.  Viewing the configuration in the effective zone database
2.  merging rules
3.  zone merging scenarios
The above are consideration to be used in conjunction with the overall steps that TechHelp24 pointed out.
Regards,
Mike Eversole
Brocade Community Manager
Anonymous
Hi all ,
Thanks for your commints .
Both Switches are having different :
Swticth Name
Domain Id
Chassis Name
also the FOS is complatible .
