Contributor
ISL between Br-5040 and Mc-6140
Br-5040 version : FOSv6.2.2; Mc6140 version : EOSn 09.09.00; Two switch mode : Mcdata Fabric ;  BR-5040 Domain ID : 6;Mc Domain ID :1 ;
connecting two switches, the following error message :
Swd:admin> switchshow
switchName:    Swd77
switchType:    58.2
switchState:    Online
switchMode:    McDATA Fabric
switchRole:    Principal
switchDomain:  6
switchId:      fffc26
switchWwn:      10:00:00:05:1e:**:**:**
zoning:        OFF
switchBeacon:  OFF
FC Router:      OFF
FC Router BB Fabric ID: 1
Area Port Media Speed State    Proto
  0  0  id    N4  Online          G-Port
  1  1  id    N4  Online          G-Port
  2  2  id    N4  Online          G-Port
  3  3  id    N4  Online          G-Port
  4  4  id    N4  Online          G-Port
  5  5  id    N4  Online          G-Port
  6  6  id    N4  Online          F-Port  21:01:00:1b:32:b2:28:e2
  7  7  id    N4  Online          F-Port  21:00:00:1b:32:92:28:e2
  8  8  id    N4  Online          F-Port  21:01:00:1b:32:b2:3f:e4
  9  9  id    N4  Online          F-Port  21:01:00:1b:32:b2:c1:e5
10  10  id    N4  Online          F-Port  21:00:00:1b:32:92:c1:e5
11  11  id    N4  Online          F-Port  21:00:00:1b:32:92:3f:e4
12  12  id    N4  Online          F-Port  21:00:00:1b:32:91:2e:4e
13  13  id    N4  No_Light
14  14  id    N4  No_Light
15  15  id    N4  No_Light
16  16  id    N4  No_Light
17  17  id    N4  No_Light
18  18  id    N4  No_Light
19  19  id    N4  No_Light
20  20  id    N2  Online          E-Port  segmented,(Security Violation)
21  21  id    N2  Online          E-Port  segmented,(Security Violation)
22  22  id    N4  No_Light
23  23  id    N4  No_Light
24  24  id    N4  No_Light
25  25  id    N4  No_Light
26  26  id    N4  No_Light
27  27  id    N4  No_Light
28  28  id    N4  No_Light
29  29  id    N4  No_Light
30  30  id    N4  No_Light
31  31  id    N4  No_Light
External Moderator
Re: ISL between Br-5040 and Mc-6140
when you are in McDATA mode,
--->>>20  20  id    N2  Online          E-Port  segmented,(Security Violation)
--->>>21  21  id    N2  Online          E-Port  segmented,(Security Violation)
2: to turn McDATA Fabric mode on
Valid McDATADefaultZone: 0 (disabled), 1 (enabled)
Valid McDATASafeZone: 0 (disabled), 1 (enabled)
Use the "interopmode" command to verify is the Default/Save zone is correct set.
To verify is the Fabric is stable, use th ecommand "fabricshow",
TechHelp24
Anonymous
techhelp is right. this is an interoprative mode issue. pls check configshow out put, if you have another fabric, and it is not segmented, you can compare the configshow output. and then thorough configure command you have to set the parameters,
chekc with fabstatsshow:
user>fabstatsshow
Description                      Count
Domain ID forcibly changed:          0
E_Port offline transitions:          1 (Last on port 1)
Reconfigurations:                 5957
Segmentations due to:
                  Loopback:          0
           Incompatibility:          0
                   Overlap:          0
                    Zoning:          0
            E_Port Segment:          0
                 Licensing:          0
           Disabled E_Port:          0
               Platform DB:          0
       Sec Incompatibility:          0
             Sec Violation:          0
                 ECP Error:          0
             Duplicate WWN:          0
            Eport Isolated:          0
user> interopmode
InteropMode: Off
Usage: InteropMode 0|1
         0: to turn it off
         1: to turn it on
you can check then with switchshow, fabricshow, and fabstatsshow
Contributor
Hi,
Thank you for your reply and prompt support!
Mc 6140 Zone information how to view (McDATADefaultZone or McDATASafeZone)
Thanks
External Moderator
Lucky,
is descripted in the Interopmode command, in the Command Reference Manual.
In order to enabling or disabling safezoning or default zoning, use the command "cfgmcdtmode"
For Operands details refer please the CLI manual.
with command "interopmode --show" can you list the current mode is set.
If the 6140 is set in safe zone mode ( as default ) you ned to enable safe zoning in IM2.
TechHelp24
External Moderator
If you are satisfied with the responses please mark as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
TechHelp24
External Moderator
Lucky,
can you please explain here in Short form How to you have solved the problem ?
You contribution help other user here to find correct answer.
Thank you.
TechHelp24
Anonymous
Hi,
I having the similiar problem...
For my case, I ISL between Mcdata4700 (firmware: 09.01.00.50) and Brocade 5100 (FOSv6.1.0j).
Mcdata are on interopmode: Open Fabric 1.0 (DID: 1) and Brocade are on interopmode: McData Fabric Mode. (DID:99)
Do I need to make any change on the Brocade Interopmode? I couldn't get outage on Mcdata production switch.
Please let me know if there is any way to configure brocade (new switch) to ISL with the Mcdata..
switch03:admin> switchshow
switchName:     switch03
switchType:     66.1
switchState:    Online
switchMode:     McDATA Open Fabric
switchDomain:   99
switchId:       fffc63
switchWwn:      10:00:00:05:1e:bb:61:bb
zoning:         OFF
switchBeacon:   OFF
FC Router:      OFF
  0   0   id    N8   No_Sync          Disabled (Persistent)
  1   1   id    N4   No_Light
  2   2   id    N4   No_Light
  3   3   id    N4   No_Light
  4   4   id    N4   No_Light
  5   5   id    N4   No_Light
  6   6   id    N4   No_Light
  7   7   id    N4   No_Light
  8   8   id    N4   No_Light
  9   9   id    N4   No_Light
10  10   id    N4   No_Light
11  11   id    N4   No_Light
12  12   id    N4   No_Light
16  16   id    1G   Online           E-Port  segmented,(Security Violation)
20  20   id    N4   No_Light
21  21   id    N4   No_Light
24  24   --    N8   No_Module        (No POD License) Disabled
25  25   --    N8   No_Module        (No POD License) Disabled
26  26   --    N8   No_Module        (No POD License) Disabled
27  27   --    N8   No_Module        (No POD License) Disabled
28  28   --    N8   No_Module        (No POD License) Disabled
29  29   --    N8   No_Module        (No POD License) Disabled
30  30   --    N8   No_Module        (No POD License) Disabled
31  31   --    N8   No_Module        (No POD License) Disabled
32  32   --    N8   No_Module        (No POD License) Disabled
33  33   --    N8   No_Module        (No POD License) Disabled
34  34   --    N8   No_Module        (No POD License) Disabled
35  35   --    N8   No_Module        (No POD License) Disabled
36  36   --    N8   No_Module        (No POD License) Disabled
37  37   --    N8   No_Module        (No POD License) Disabled
38  38   --    N8   No_Module        (No POD License) Disabled
39  39   --    N8   No_Module        (No POD License) Disabled
switch03:admin> fabstatsshow
Description                      Count
E_Port offline transitions:          0
Reconfigurations:                    0
                  Loopback:          0
           Incompatibility:          0
                   Overlap:          0
                    Zoning:          0
            E_Port Segment:          0
                 Licensing:          0
           Disabled E_Port:          0
               Platform DB:          0
             Sec Violation:          1 <
                 ECP Error:          0
             Duplicate WWN:          0
  Eport IsolatedAD header conflict:          0
Thanks.
External Moderator
chinseong,
please move you question in a NEW Threads, and i will provide to give you correct and adequate Instructions.
A NEW threads is required to awoid aconfusion as follow reason:
the owner this threads Lucky_li, market the threads here as answered but he marked some answer here as valuable which are incorrect.
From hemant.kumar
2. Apr 6, 2010 8:45 AM in response to: TechHelp24
"fabstatshow" don't solve anything.
I'll proide to remove this answer.
Thank You.
TechHelp24
Contributor
Hi,
Thank you for you help ,
Very grateful to techhelp24,his answer si correct.
Thanks!
