Turn on suggestions
Showing results for
02-24-2009 12:17 PM
I have noticed with Brocade 4100s, 6.1.0c firmware. The ISLs won't trunk consistently. Some time it does, some time both the links will show up as the trunk master. Has any one seen this?
03-09-2009 02:55 PM
Make sure your ISLs are connected on "consecutive" ports, or the same port groups.
for example: 0,1, 2, 3
