Anonymous
ISL Issue
Hello,
I have a problem with an ISL, this not established correctly. When I am checking the link with the command "nbrStateShow <port>", display that are in NB_ST_INIT state.
TLALPAN1:admin>  nbrStateShow 9/1
Local Domain ID: 113
Local Port     Domain     Remote Port     State
    65                -1           -1             NB_ST_INIT
Anonymous
Re: ISL Issue
Which status do you have on the physical level?
Are both ends in sync?
Check on both switches if you segmentation issues.
Andreas
Anonymous
Re: ISL Issue
Hi Andreas:
The ISL port and link are actives. Additional I comment to you that I have 2 ISL in the fabric (Tlalpan1 - Santafe1) and only one is working correctly.
TLALPAN1:admin> fabricshow
Switch ID   Worldwide Name           Enet IP Addr    FC IP Addr      Name
113: fffc71 10:00:00:05:1e:ba:52:00 10.15.2.71      0.0.0.0        >"TLALPAN1"
115: fffc73 10:00:00:05:1e:ba:60:00 10.16.1.73      0.0.0.0         "SANTAFE1"
The Fabric has 2 switches
TLALPAN1:admin> islshow
  1: 64-> 64 10:00:00:05:1e:ba:60:00 115 SANTAFE1        sp: 10.000G bw: 10.000G
  2: 65-> 65 10:00:00:05:1e:ba:60:00 115 SANTAFE1        sp: 10.000G bw: 10.000G
TLALPAN1:admin> switchshow | grep 714
64    9    0   714000   id    10G   Online      FC  LS E-Port  10:00:00:05:1e:ba:60:00 "SANTAFE1"
65    9    1   714100   id    10G   Online      FC  LS E-Port  10:00:00:05:1e:ba:60:00 "SANTAFE1" (downstream)
TLALPAN1:admin> nbrStateShow 9/0
    64          115           64        NB_ST_FULL
    65           -1           -1        NB_ST_INIT
_______________________________________________________________________________
SANTAFE1:admin> fabricshow
SANTAFE1:admin> islshow
  1: 64-> 64 10:00:00:05:1e:ba:52:00 113 TLALPAN1        sp: 10.000G bw: 10.000G
  2: 65-> 65 10:00:00:05:1e:ba:52:00 113 TLALPAN1        sp: 10.000G bw: 10.000G
SANTAFE1:admin> switchshow | grep 734
64    9    0   734000   id    10G   Online      FC  LS E-Port  10:00:00:05:1e:ba:52:00 "TLALPAN1"
65    9    1   734100   id    10G   Online      FC  LS E-Port  10:00:00:05:1e:ba:52:00 "TLALPAN1" (upstream)
SANTAFE1:admin> nbrStateShow 9/0
Local Domain ID: 115
    64          113           64        NB_ST_FULL
SANTAFE1:admin> nbrStateShow 9/1
    65           -1           -1        NB_ST_INIT
External Moderator
Re: ISL Issue
can you collect and post please entire output from
"switchshow" and "slotshow"
TechHelp24
Anonymous
Re: ISL Issue
Hi,
can it be possible that you have not enough buffer free? You can check this with portbuffershow.
The used amount of buffer are configured with portcfglongdistance.
Brocade FOS Admin guide tells us this:
The 10 Gbps FC10-6 blade has two port groups of three ports each. For extended ISLs, all buffers available to a group are used to support one port at up to 100 km.
If this is a buffer issue you can try the second port group to create an ISL on both ends.
I hope this helps,
Andreas
Anonymous
Re: ISL Issue
Hi Antonio:
This is the output of the commands requested.
switchName:     TLALPAN1
switchType:     62.3
switchState:    Online
switchMode:     Native
switchRole:     Principal
switchDomain:   113
switchId:       fffc71
switchWwn:      10:00:00:05:1e:ba:52:00
zoning:         ON (TLALPAN1_INTERMIX)
switchBeacon:   OFF
FC Router:      OFF
FC Router BB Fabric ID: 128
Address Mode:   0
Index Slot Port Address Media Speed State     Proto
  0    1    0   710000   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b2:47
  1    1    1   710100   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:02
  2    1    2   710200   id    N4   Online      FC  F-Port  21:00:00:1b:32:95:e0:34
  3    1    3   710300   id    N8   No_Sync     FC  Disabled (Persistent)
  4    1    4   710400   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:44
  5    1    5   710500   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:c8:84
  6    1    6   710600   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b2:1a
  7    1    7   710700   id    4G   No_Light    FC  Disabled
  8    1    8   710800   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:20
  9    1    9   710900   id    N8   No_Light    FC
10    1   10   710a00   id    N2   Online      FC  F-Port  21:00:00:e0:8b:8f:08:78
11    1   11   710b00   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:c2:82
12    1   12   710c00   id    N8   No_Light    FC
13    1   13   710d00   id    4G   Online      FC  F-Port  21:00:00:24:ff:20:8a:7c
14    1   14   710e00   id    4G   Online      FC  F-Port  21:00:00:24:ff:20:89:98
15    1   15   710f00   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:21
128    1   16   718000   id    4G   No_Light    FC  Disabled
129    1   17   718100   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:53:a4
130    1   18   718200   id    N8   No_Light    FC
131    1   19   718300   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:01
132    1   20   718400   id    4G   No_Light    FC
133    1   21   718500   id    N4   Online      FC  F-Port  21:01:00:1b:32:ba:97:10
134    1   22   718600   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:52:bc
135    1   23   718700   id    N8   No_Light    FC  Disabled
136    1   24   718800   id    4G   No_Light    FC  Disabled
137    1   25   718900   id    4G   No_Light    FC
138    1   26   718a00   id    N4   Online      FC  F-Port  50:01:04:f0:00:8a:d9:db
139    1   27   718b00   id    N4   Online      FC  F-Port  50:06:0e:80:06:fe:36:24
140    1   28   718c00   id    N8   No_Light    FC
141    1   29   718d00   id    4G   No_Light    FC
142    1   30   718e00   id    N2   Online      FC  F-Port  50:01:04:f0:00:8a:da:2f
143    1   31   718f00   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:d4:24
256    1   32   718880   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:2e
257    1   33   718980   id    N8   No_Light    FC
258    1   34   718a80   id    N4   Online      FC  F-Port  50:01:04:f0:00:8a:da:77
259    1   35   718b80   id    4G   Online      FC  F-Port  50:06:0e:80:10:05:76:90
260    1   36   718c80   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:28
261    1   37   718d80   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:51:2e
262    1   38   718e80   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:51:a0
263    1   39   718f80   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:21
264    1   40   718080   id    N8   No_Light    FC
265    1   41   718180   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:50:48
266    1   42   718280   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:51:e4
267    1   43   718380   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:0c
268    1   44   718480   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:d0:4c
269    1   45   718580   id    4G   Online      FC  F-Port  21:00:00:24:ff:20:87:7a
270    1   46   718680   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:50:98
271    1   47   718780   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:00
16    2    0   711000   id    N8   Online      FC  F-Port  50:06:0e:80:16:02:4b:61
17    2    1   711100   id    N8   No_Light    FC
18    2    2   711200   id    N8   No_Light    FC
19    2    3   711300   id    4G   Online      FC  F-Port  50:06:0e:80:10:0a:a4:04
20    2    4   711400   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:2a
21    2    5   711500   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b1:63
22    2    6   711600   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:d0:70
23    2    7   711700   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b2:0d
24    2    8   711800   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:04
25    2    9   711900   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b2:0a
26    2   10   711a00   id    N4   Online      FC  F-Port  21:00:00:1b:32:9a:9e:0a
27    2   11   711b00   id    4G   No_Light    FC  Disabled
28    2   12   711c00   id    N8   Online      FC  F-Port  50:06:0e:80:16:02:4b:05
29    2   13   711d00   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:53:56
30    2   14   711e00   id    4G   Online      FC  F-Port  21:00:00:24:ff:33:aa:b0
31    2   15   711f00   id    N8   No_Light    FC
144    2   16   719000   id    4G   No_Light    FC  Disabled
145    2   17   719100   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:51:86
146    2   18   719200   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:50:76
147    2   19   719300   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:07
148    2   20   719400   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:00
149    2   21   719500   id    4G   Online      FC  F-Port  21:00:00:24:ff:20:87:8a
150    2   22   719600   id    N8   No_Light    FC  Disabled (Persistent)
151    2   23   719700   id    N8   Online      FC  F-Port  50:06:0e:80:16:02:4b:22
152    2   24   719800   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:23
153    2   25   719900   id    N4   Online      FC  F-Port  50:06:0b:00:00:3a:ef:ac
154    2   26   719a00   id    N2   Online      FC  F-Port  50:01:04:f0:00:8a:d9:cf
155    2   27   719b00   id    N8   Online      FC  F-Port  21:00:00:24:ff:30:b1:e2
156    2   28   719c00   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:03
157    2   29   719d00   id    N8   No_Light    FC
158    2   30   719e00   id    N4   Online      FC  F-Port  50:01:04:f0:00:8a:da:17
159    2   31   719f00   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:d4:28
272    2   32   719880   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:0a
273    2   33   719980   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:d5:ec
274    2   34   719a80   id    N4   Online      FC  F-Port  50:01:04:f0:00:8a:da:6b
275    2   35   719b80   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b1:64
276    2   36   719c80   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:0d
277    2   37   719d80   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:4f:44
278    2   38   719e80   id    N8   Online      FC  F-Port  21:00:00:24:ff:30:c2:1b
279    2   39   719f80   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b1:e7
280    2   40   719080   id    N8   No_Light    FC  Disabled (Persistent)
281    2   41   719180   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:4f:60
282    2   42   719280   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:52:96
283    2   43   719380   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:20
284    2   44   719480   id    2G   No_Light    FC
285    2   45   719580   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:50:5c
286    2   46   719680   id    4G   Online      FC  F-Port  21:00:00:24:ff:28:10:72
287    2   47   719780   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:2c
32    3    0   712000   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:64
33    3    1   712100   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b3:72
34    3    2   712200   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b1:62
35    3    3   712300   id    4G   Online      FC  F-Port  1 N Port + 2 NPIV public
36    3    4   712400   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:06
37    3    5   712500   id    4G   Online      FC  F-Port  1 N Port + 2 NPIV public
38    3    6   712600   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b2:46
39    3    7   712700   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:d0:22
40    3    8   712800   id    N8   Online      FC  F-Port  50:06:0e:80:16:02:4b:24
41    3    9   712900   id    N8   No_Light    FC
42    3   10   712a00   id    4G   Online      FC  F-Port  21:00:00:1b:32:9a:65:0f
43    3   11   712b00   id    4G   No_Light    FC  Disabled (Persistent)
44    3   12   712c00   id    N4   Online      FC  F-Port  50:06:0e:80:10:05:76:91
45    3   13   712d00   id    N8   No_Light    FC
46    3   14   712e00   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:d0:13
47    3   15   712f00   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:23
160    3   16   71a000   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:2b
161    3   17   71a100   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:4f:ac
162    3   18   71a200   id    4G   Online      FC  F-Port  21:00:00:24:ff:28:10:ab
163    3   19   71a300   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:26
164    3   20   71a400   id    N8   No_Light    FC  Disabled
165    3   21   71a500   id    4G   Online      FC  F-Port  21:00:00:24:ff:20:87:a2
166    3   22   71a600   id    N8   No_Sync     FC  Disabled (Persistent)
167    3   23   71a700   id    N8   Online      FC  F-Port  50:06:0e:80:16:02:4b:42
168    3   24   71a800   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:0b
169    3   25   71a900   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:d5:b6
170    3   26   71aa00   id    N4   Online      FC  F-Port  50:01:04:f0:00:8a:da:23
171    3   27   71ab00   id    N4   Online      FC  F-Port  50:06:0e:80:06:fe:36:25
172    3   28   71ac00   id    4G   No_Light    FC
173    3   29   71ad00   id    4G   No_Light    FC
174    3   30   71ae00   id    N4   Online      FC  F-Port  50:01:04:f0:00:8a:da:0b
175    3   31   71af00   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:c1:ea
288    3   32   71a880   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:03
289    3   33   71a980   id    N4   Online      FC  F-Port  21:01:00:1b:32:ba:82:13
290    3   34   71aa80   id    N2   Online      FC  F-Port  50:01:04:f0:00:8a:da:5f
291    3   35   71ab80   id    4G   Online      FC  F-Port  50:06:0e:80:10:05:76:94
292    3   36   71ac80   id    N4   Online      FC  F-Port  50:06:0e:80:10:0a:a4:01
293    3   37   71ad80   id    N4   Online      FC  F-Port  21:00:00:1b:32:9a:1a:16
294    3   38   71ae80   id    N8   Online      FC  F-Port  21:00:00:24:ff:30:b2:0b
295    3   39   71af80   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:25
296    3   40   71a080   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b2:20
297    3   41   71a180   id    N4   Online      FC  F-Port  21:01:00:1b:32:b5:e0:34
298    3   42   71a280   id    N4   Online      FC  F-Port  21:00:00:1b:32:9a:8f:0a
299    3   43   71a380   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:2f
300    3   44   71a480   id    N8   No_Light    FC  Disabled (Persistent)
301    3   45   71a580   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:4f:e8
302    3   46   71a680   id    4G   Online      FC  F-Port  21:00:00:24:ff:34:34:ce
303    3   47   71a780   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:01
48    4    0   713000   id    N8   Online      FC  F-Port  50:06:0e:80:16:02:4b:43
49    4    1   713100   id    N4   Online      FC  F-Port  50:06:0b:00:00:66:76:72
50    4    2   713200   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:c2:13
51    4    3   713300   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:ca:bc
52    4    4   713400   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b1:ee
53    4    5   713500   id    N8   No_Light    FC
54    4    6   713600   id    N8   No_Light    FC
55    4    7   713700   id    4G   No_Light    FC
56    4    8   713800   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b1:e4
57    4    9   713900   id    N2   Online      FC  F-Port  21:00:00:e0:8b:8f:a4:72
58    4   10   713a00   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:66
59    4   11   713b00   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:cf:0e
60    4   12   713c00   id    4G   No_Light    FC
61    4   13   713d00   id    N8   No_Light    FC
62    4   14   713e00   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b1:b4
63    4   15   713f00   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:45
176    4   16   71b000   id    N8   No_Light    FC  Disabled
177    4   17   71b100   id    4G   Online      FC  F-Port  21:00:00:24:ff:20:87:70
178    4   18   71b200   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:52:64
179    4   19   71b300   id    N8   Online      FC  F-Port  50:06:0e:80:16:02:4b:47
180    4   20   71b400   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:67
181    4   21   71b500   id    N8   No_Light    FC  Disabled (Persistent)
182    4   22   71b600   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:52:a0
183    4   23   71b700   id    N8   Online      FC  F-Port  50:06:0e:80:16:02:4b:46
184    4   24   71b800   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:27
185    4   25   71b900   id    N4   Online      FC  F-Port  50:06:0b:00:00:3a:ef:d2
186    4   26   71ba00   id    N4   Online      FC  F-Port  50:01:04:f0:00:8a:d9:f3
187    4   27   71bb00   id    N8   Online      FC  F-Port  21:00:00:24:ff:30:b2:15
188    4   28   71bc00   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:0e
189    4   29   71bd00   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:b2:0c
190    4   30   71be00   id    N2   Online      FC  F-Port  50:01:04:f0:00:8a:d9:ff
191    4   31   71bf00   id    N8   Online      FC  F-Port  21:00:00:24:ff:30:b2:2d
304    4   32   71b880   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:26
305    4   33   71b980   id    N8   No_Light    FC
306    4   34   71ba80   id    N4   Online      FC  F-Port  50:01:04:f0:00:8a:da:47
307    4   35   71bb80   id    N8   Online      FC  F-Port  21:00:00:24:ff:30:c2:10
308    4   36   71bc80   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:07
309    4   37   71bd80   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:d6:20
310    4   38   71be80   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:c2:1a
311    4   39   71bf80   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:09
312    4   40   71b080   id    N8   In_Sync     FC
313    4   41   71b180   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:4f:40
314    4   42   71b280   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:50:ac
315    4   43   71b380   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:24
316    4   44   71b480   id    N8   No_Light    FC
317    4   45   71b580   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:53:54
318    4   46   71b680   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:51:5a
319    4   47   71b780   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:04
384    5    0   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
385    5    1   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
386    5    2   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
387    5    3   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
388    5    4   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
389    5    5   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
390    5    6   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
391    5    7   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
392    5    8   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
393    5    9   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
394    5   10   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
395    5   11   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
396    5   12   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
397    5   13   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
398    5   14   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
399    5   15   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
400    5   16   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
401    5   17   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
402    5   18   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
403    5   19   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
404    5   20   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
405    5   21   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
406    5   22   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
407    5   23   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
408    5   24   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
409    5   25   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
410    5   26   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
411    5   27   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
412    5   28   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
413    5   29   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
414    5   30   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
415    5   31   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
416    8    0   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
417    8    1   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
418    8    2   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
419    8    3   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
420    8    4   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
421    8    5   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
422    8    6   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
423    8    7   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
424    8    8   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
425    8    9   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
426    8   10   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
427    8   11   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
428    8   12   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
429    8   13   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
430    8   14   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
431    8   15   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
432    8   16   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
433    8   17   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
434    8   18   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
435    8   19   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
436    8   20   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
437    8   21   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
438    8   22   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
439    8   23   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
440    8   24   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
441    8   25   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
442    8   26   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
443    8   27   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
444    8   28   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
445    8   29   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
446    8   30   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
447    8   31   ------   cu    8G   No_Sync     FC  Disabled (Persistent)
64    9    0   714000   id    10G   Online      FC  LS E-Port  10:00:00:05:1e:ba:60:00 "SANTAFE1" (downstream)
66    9    2   714200   id    10G   No_Light    FC  LS Disabled (Persistent)
67    9    3   714300   id    10G   No_Light    FC  Disabled (Persistent)
68    9    4   714400   id    10G   No_Light    FC  Disabled (Persistent)
69    9    5   714500   id    10G   No_Light    FC  Disabled (Persistent)
80   10    0   715000   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:c2:de
81   10    1   715100   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:c2:12
82   10    2   715200   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:62
83   10    3   715300   id    4G   Online      FC  F-Port  1 N Port + 1 NPIV public
84   10    4   715400   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:c8:96
85   10    5   715500   id    N8   No_Light    FC
86   10    6   715600   id    4G   Online      FC  F-Port  1 N Port + 1 NPIV public
87   10    7   715700   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:d4:2a
88   10    8   715800   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:c2:25
89   10    9   715900   id    N4   Online      FC  F-Port  21:01:00:1b:32:ba:b3:0b
90   10   10   715a00   id    N4   Online      FC  F-Port  21:00:00:1b:32:9a:7a:0b
91   10   11   715b00   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:63
92   10   12   715c00   id    4G   No_Light    FC  Disabled
93   10   13   715d00   id    4G   Online      FC  F-Port  10:00:00:00:c9:a1:c8:88
94   10   14   715e00   id    N8   No_Light    FC
95   10   15   715f00   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:25
208   10   16   71d000   id    4G   No_Light    FC  Disabled
209   10   17   71d100   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:50:c6
210   10   18   71d200   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:50:7c
211   10   19   71d300   id    N8   No_Light    FC
212   10   20   71d400   id    N8   No_Light    FC  Disabled
213   10   21   71d500   id    4G   Online      FC  F-Port  21:00:00:24:ff:20:88:bc
214   10   22   71d600   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:4f:ca
215   10   23   71d700   id    N8   Online      FC  F-Port  50:06:0e:80:16:02:4b:65
216   10   24   71d800   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:0f
217   10   25   71d900   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:52:6c
218   10   26   71da00   id    4G   Online      FC  F-Port  1 N Port + 1 NPIV public
219   10   27   71db00   id    N4   Online      FC  F-Port  50:06:0e:80:06:fe:36:34
220   10   28   71dc00   id    N4   Online      FC  F-Port  50:06:0e:80:10:0a:a4:02
221   10   29   71dd00   id    N4   Online      FC  F-Port  21:01:00:1b:32:ba:1a:16
222   10   30   71de00   id    N4   Online      FC  F-Port  50:01:04:f0:00:8a:d9:e7
223   10   31   71df00   id    N4   Online      FC  F-Port  21:01:00:1b:32:ba:9e:0a
336   10   32   71d880   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:22
337   10   33   71d980   id    4G   Online      FC  F-Port  21:00:00:24:ff:30:c2:ce
338   10   34   71da80   id    N4   Online      FC  F-Port  50:01:04:f0:00:8a:da:3b
339   10   35   71db80   id    N8   No_Light    FC  Disabled
340   10   36   71dc80   id    4G   Online      FC  F-Port  50:06:0e:80:10:0a:a4:03
341   10   37   71dd80   id    N8   No_Light    FC
342   10   38   71de80   id    N8   No_Light    FC
343   10   39   71df80   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:29
344   10   40   71d080   id    N8   Online      FC  F-Port  21:00:00:24:ff:30:c2:df
345   10   41   71d180   id    N8   No_Light    FC
346   10   42   71d280   id    4G   Online      FC  F-Port  21:00:00:24:ff:21:4f:f8
347   10   43   71d380   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:05
348   10   44   71d480   id    N8   No_Light    FC
349   10   45   71d580   id    N8   No_Light    FC  Disabled (SW Security Violation)
350   10   46   71d680   id    4G   Online      FC  F-Port  21:00:00:24:ff:20:8b:18
351   10   47   71d780   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:08
96   11    0   716000   id    N8   No_Sync     FC  Disabled (Persistent)
97   11    1   716100   id    2G   Online      FC  F-Port  50:05:07:60:28:bf:15:47
98   11    2   716200   id    2G   Online      FC  F-Port  50:01:04:f0:00:98:b3:72
99   11    3   716300   id    N8   No_Sync     FC  Disabled (Persistent)
100   11    4   716400   id    N8   No_Sync     FC  Disabled (Persistent)
101   11    5   716500   id    2G   Online      FC  F-Port  50:01:04:f0:00:98:b3:76
102   11    6   716600   id    N8   No_Sync     FC  Disabled (Persistent)
103   11    7   716700   id    N8   No_Sync     FC  Disabled (Persistent)
104   11    8   716800   id    N8   No_Sync     FC  Disabled (Persistent)
105   11    9   716900   id    N8   No_Sync     FC  Disabled (Persistent)
106   11   10   716a00   id    N8   No_Sync     FC  Disabled (Persistent)
107   11   11   716b00   id    N8   No_Sync     FC  Disabled (Persistent)
108   11   12   716c00   id    N8   No_Sync     FC  Disabled (Persistent)
109   11   13   716d00   id    2G   Online      FC  F-Port  50:01:04:f0:00:98:b3:77
110   11   14   716e00   id    N8   No_Sync     FC  Disabled (Persistent)
111   11   15   716f00   id    N8   No_Sync     FC  Disabled (Persistent)
224   11   16   71e000   id    N8   No_Sync     FC  Disabled (Persistent)
225   11   17   71e100   id    2G   Online      FC  F-Port  50:01:04:f0:00:8a:da:32
226   11   18   71e200   id    N8   No_Sync     FC  Disabled (Persistent)
227   11   19   71e300   id    N8   No_Sync     FC  Disabled (Persistent)
228   11   20   71e400   id    N8   No_Sync     FC  Disabled (Persistent)
229   11   21   71e500   id    4G   No_Light    FC
230   11   22   71e600   id    N8   No_Sync     FC  Disabled (Persistent)
231   11   23   71e700   id    N8   No_Sync     FC  Disabled (Persistent)
232   11   24   71e800   id    2G   Online      FC  F-Port  50:01:04:f0:00:8a:da:3e
233   11   25   71e900   id    2G   Online      FC  F-Port  50:01:04:f0:00:98:b3:75
234   11   26   71ea00   id    N8   No_Sync     FC  Disabled (Persistent)
235   11   27   71eb00   id    N8   No_Sync     FC  Disabled (Persistent)
236   11   28   71ec00   id    N8   No_Sync     FC  Disabled (Persistent)
237   11   29   71ed00   id    2G   No_Sync     FC  Disabled (Persistent)
238   11   30   71ee00   id    N8   No_Sync     FC  Disabled (Persistent)
239   11   31   71ef00   id    N8   No_Sync     FC  Disabled (Persistent)
112   12    0   717000   id    N8   No_Sync     FC  Disabled (Persistent)
113   12    1   717100   id    2G   Online      FC  F-Port  50:05:07:60:28:bf:15:7f
114   12    2   717200   id    2G   Online      FC  F-Port  50:01:04:f0:00:98:b3:78
115   12    3   717300   id    N8   No_Sync     FC  Disabled (Persistent)
116   12    4   717400   id    N8   No_Sync     FC  Disabled (Persistent)
117   12    5   717500   id    N8   No_Sync     FC  Disabled (Persistent)
118   12    6   717600   id    N8   No_Sync     FC  Disabled (Persistent)
119   12    7   717700   id    4G   No_Light    FC
120   12    8   717800   id    N8   No_Sync     FC  Disabled (Persistent)
121   12    9   717900   id    2G   Online      FC  F-Port  50:01:04:f0:00:98:b3:73
122   12   10   717a00   id    N8   No_Sync     FC  Disabled (Persistent)
123   12   11   717b00   id    4G   No_Light    FC
124   12   12   717c00   id    N8   No_Sync     FC  Disabled (Persistent)
125   12   13   717d00   id    N8   No_Sync     FC  Disabled (Persistent)
126   12   14   717e00   id    N8   No_Sync     FC  Disabled (Persistent)
127   12   15   717f00   id    4G   Online      FC  F-Port  50:06:0e:80:16:02:4b:27
240   12   16   71f000   id    N8   No_Sync     FC  Disabled (Persistent)
241   12   17   71f100   id    N8   No_Sync     FC  Disabled (Persistent)
242   12   18   71f200   id    N8   No_Sync     FC  Disabled (Persistent)
243   12   19   71f300   id    N4   Online      FC  F-Port  50:06:0e:80:06:fe:36:35
244   12   20   71f400   id    2G   Online      FC  F-Port  50:01:04:f0:00:8a:da:6e
245   12   21   71f500   id    N8   No_Sync     FC  Disabled (Persistent)
246   12   22   71f600   id    N8   No_Sync     FC  Disabled (Persistent)
247   12   23   71f700   id    N8   No_Sync     FC  Disabled (Persistent)
248   12   24   71f800   id    2G   Online      FC  F-Port  50:01:04:f0:00:8a:da:63
249   12   25   71f900   id    2G   Online      FC  F-Port  50:01:04:f0:00:98:b3:7e
250   12   26   71fa00   id    2G   No_Sync     FC  Disabled (Persistent)
251   12   27   71fb00   id    N8   No_Sync     FC  Disabled (Persistent)
252   12   28   71fc00   id    N8   No_Sync     FC  Disabled (Persistent)
253   12   29   71fd00   id    4G   No_Light    FC
254   12   30   71fe00   --    N8   No_Module   FC  Disabled (Persistent)
255   12   31   71ff00   id    4G   Online      FC  F-Port  50:06:0e:80:05:74:86:2d
TLALPAN1:admin>
TLALPAN1:admin> slotshow
Slot   Blade Type     ID    Status
  1     SW BLADE     51     ENABLED
  2     SW BLADE     51     ENABLED
  3     SW BLADE     51     ENABLED
  4     SW BLADE     51     ENABLED
  5     CORE BLADE   52     ENABLED
  6     CP BLADE     50     ENABLED
  7     CP BLADE     50     ENABLED
  8     CORE BLADE   52     ENABLED
  9     SW BLADE     39     ENABLED
10     SW BLADE     51     ENABLED
11     SW BLADE     55     ENABLED
12     SW BLADE     55     ENABLED
Anonymous
Re: ISL Issue
Hi Andreas:
This is the buffers in the ISL ports:
TLALPAN1:admin> portbuffershow 9/0
User     Port     Lx           Max/Resv    Buffer Needed          Link   Remaining
Port     Type    Mode          Buffers     Usage  Buffers     Distance  Buffers
64        E     LS             252        252     252            42km        0
TLALPAN1:admin>
TLALPAN1:admin> portbuffershow 9/1
65        E     LS             252        252     252            42km        0
