Contributor
Accepted Solution
ISL-DWDM FillWord setting
Dear Brocade Frends,
We have 2 Datacenter whit Dual Fabric
Datacenter 1 2xBrocade 5300 80Port 2xISL DWDM
Datacenter 2 2xBrocade 6510 48Port 2xISL DWDM
I see whit Portcfgshow on 5300 the Fillword is set to 2 (we see a lot of B2B Zerro)
On the 6510 there is no FillWord (16Gb Switch)
My Question is what is the right setting for this Port?
best regards
Ernst
Broadcom Moderator
Re: ISL-DWDM FillWord setting
[ Edited ]
Hello,
Fillword configuration is not an issue because switches are negotiated the right parameters automatically.
Concerning the BB Credit at 0, until you do not have discards, this is normal.
Check the average frames size transmitted and see if this match with the BBC credit calculation for the specific distance between the sites and what is configured.
Contributor
Dear Thierry,
In the moment the FillWord on the ISL is set to 2 on all 5300 Switches, shut we changed or not ?
Broadcom Moderator
No this is fine.
Valued Contributor
Fillword 2 is the industry standard.
As far as I understand, fillword setting, even if it is not correct, can not be a reason for any b2b zero issues.
