Occasional Contributor
ISL 5300 and 8510-4 switches
Hello,
I have a question on ISL.  I am about to ISL a 5300 to 8510-4. The 5300 is currently the fabric principal, I already set the domain ID on the 8510 to a unique, also did a cfgclear.
8510 – Output.
NYAPBCADE01:dmotiela> fabricprincipal
Principal Selection Mode: Disable
Principal Switch Selection Priority: 0
5300 – Output
nyapbcade11:dmotiela> fabricprincipal
Principal Selection Mode: Enable
Principal Switch Selection Priority: 0x1
My Question is, when I logged in to the GUI of the 8510, the switch mode is showing Principal with Mode Type 1.  Will this change from Principal to subordinate once I ISL them?
Thanks.
Deryck
Contributor
Re: ISL 5300 and 8510-4 switches
Yes.It will will be changed to subordinate after establish ISL to merge it.
Regards,
Felix.
