Anonymous
IP connectivity loss on 3800 (telnet & web)
I search on the topic in this forum, and I found a few similar problems.
Anonymous
Re: IP connectivity loss on 3800 (telnet & web)
Hi,We have the same problem here with 3 of our 4 switchs. We loss connection 1h after a reboot. What I have found at this time: I have to remove the syslog config and the snmp config in the switch. I'm still troubleshooting...and I will let you know if I found something.
Anonymous
Ok,Ministere des Finances
Anonymous
Thanks Eric ... we will give it a try.
Anonymous
do you use any telnet scripts or snmp scripts?
Anonymous
Supposedly, this problem relates to the Ethernet port running out of sockets, and it's fixed in v3.1.3 firmware.- Mariusz
Anonymous
Hi i_m_fdetEric
Anonymous
Hi Mariusz,Eric
