Anonymous
IP connectivity fails through Cisco switch
Have a strange issue involving 2 3900 switches running 4.2.2. The management ports are both connected to a single Cisco 2924 switch. 1 switch works fine, however, the other is not "pingable.
Anonymous
Re: IP connectivity fails through Cisco switch
We've had this problem when the Cisco switch is set to 100/Full and we set to Auto Negotiate. We have to set our switch the same as the cisco switch for it to work right.I did have a problem last week with a cisco switch disabling a port because it had too many errors on that port. Check on that too.
Anonymous
For all our Brocade equipments we have set the speed at 10 full for Brocade and Cisco ports, we have no more problems of disconnection, ping, or time-out for java applets.
