Turn on suggestions
Showing results for
07-01-2013 09:17 AM
I need help in setting up IFL between DCX-4s, each connecting using DWDM. Right now site-A is active(production), this week we will be bring site-B up. To configure IFL between dcx-4s what configuration changes should i make(if possible please provide step by step process. I don't want to screw this up, site-A is in production). I was looking into brocade documents i couldn't find IFL between two DCX-4s.
Site-A Site-B
DCX-4s Fab-A(E)------ONS ------DWDM------ONS------(EX)DCX-4s Fab-A
DCX-4s Fab-B(E)------ONS ------DWDM------ONS------(EX)DCX-4s Fab-B
Appreciate your help.
Thank you
San.
07-01-2013 12:16 PM
shwesan,
in order to configure a Port as EX_Port, you need IR= Integrated Routing License or FX8-24 Blade.
here is a great article about how to configure such IFL, the Principe is the same
http://wikibon.org/wiki/v/How_to_configure_FCIP_on_Brocade_7500's#Creating_FCIP_Connections
