Anonymous
IE java plugin problem when accessing brocade switch
Due to a new security policy I've had to quit using Mozilla/Firefox browsers - Only IE is allowed. The problem is that I cannot get IE5.5 with the Sun Java Plugin to access any Switch. This is not a problem with Java per say, since the same java version worked under Mozilla, but in IE it will not work. I've tried several different versions from 1.3.1_04 up to the latest 1.4.2_04 . . . nothing helps.
Anonymous
Re: IE java plugin problem when accessing brocade switch
I've got the same Java versions running but with IE 6.0. I have no problems. Have you thought about upgrading IE?
