Contributor
Accepted Solution
ICL between DCX4-S and X6-4 Directors?
We just got two new X6-4 directors for our fabrics and they look amazing. But for a transition time we need to use old and new.
Are the ICL connections between our old DCX4-S Directors and the new X6-4 Directors possible? Or do I just have to dedicate some of the port on the old ones and do a regular trunk between them?
Firmware level is 7.4.1e on the old ones and 8.0.2a on the new ones.
Valued Contributor
Re: ICL between DCX4-S and X6-4 Directors?
ISL will work between DCX (including 4S) and X6
ISL & ICL will work between 8510 (4/8 models) and X6
Contributor
[ Edited ]
Thats what I thought. A couple of generations to old. ISL Trunk it is. Thanks :)
Valued Contributor
I'd say the main problem is not about the generations. It's about the proprietary copper connector of the ICL ports on the 8G chassis.
