Anonymous
IBM PPRC thru DCX does not work out
Hi Guys,
I am trying to deploy disk replication (pprc) over DWDM link, using two new DCX directors. In each director I have a 6 ports of 10 Gb card installed. Those ports are connected directly to Cisco ONS.  Actually I have already merged 2 DCX into a single Fabric between two sites.
When I try to stablish pprcpaths, I check available pprcports and there are the available ports according to zones that were previously defined. the problem here is when I try o stablish pprc paths, the operation fails. Acording to IBM specialists, there is an issue related to login of the F ports when mkpprcpath command is issued, it makes some others queries that are failing.
Fabric is Ok, and all storage ports are ok. Zonning is Ok. Do you have any clue? what else can I check in order to find out where the problem is?
Thanks!
Juan i Téllez
Here are some of switch and storage outputs:
Switchshow DCX  Site 1:
Index Slot Port Address Media Speed State Proto
19 1 19 011300 id N8 No_Light
20 1 20 011400 id N4 Online F-Port 50:05:07:63:06:38:05:e5
21 1 21 011500 id N4 Online F-Port 50:05:07:63:06:33:05:e5
22 1 22 011600 id N4 Online F-Port 50:05:07:63:06:1c:00:12
23 1 23 011700 id N4 Online F-Port 50:05:07:63:06:11:00:12I0210
24 1 24 011800 id N8 No_Light
DS8000 lsioport source:
Date/Time: 8 de diciembre de 2009 06:00:26 PM GMT IBM DSCLI Version: 5.3.1.183 DS: IBM.2107-75YY491
ID WWPN State Type topo portgrp Speed
I0210 5005076306110012 Online Fibre Channel-SW SCSI-FCP 0 4 Gb/s
Switchshow DCX  Site 2:
19 1 19 021300 id N8 No_Light
20 1 20 021400 id N4 Online F-Port 50:05:07:63:07:13:c4:03
21 1 21 021500 id N4 Online F-Port 50:05:07:63:06:33:c5:49
22 1 22 021600 id N4 Online F-Port 50:05:07:63:07:18:84:03
23 1 23 021700 id N4 Online F-Port 50:05:07:63:07:13:84:03
I0232
24 1 24 021800 id N8 No_Light
DS8000 lsioport target:
dscli> lsioport -l I0232
Date/Time: 8 de diciembre de 2009 06:03:13 PM GMT IBM DSCLI Version: 5.3.1.183 DS: IBM.2107-75XX101
I0232 5005076307138403 Online Fibre Channel-SW SCSI-FCP 0 4 Gb/s
dscli> lsavailpprcport -l -remotewwnn 5005076307FFC403 00:00
Date/Time: 2 de diciembre de 2009 06:27:54 PM GMT IBM DSCLI
Local Port Attached Port Type Switch ID Switch Port
I0010 I0230 FCP NA NA
I0140 I0300 FCP NA NA
I0210 I0232 FCP NA NA
I0231 I0230 FCP NA NA
I0300 I0300 FCP NA NA
I0340 I0302 FCP NA NA
I am trying to make pprcpath from
I0210 to I0232, but it does not work out:
dscli> mkpprcpath -dev IBM.2107-75YY491 -remotedev IBM.2107-75XX101 -remotewwnn 5005076307FFC403 -srclss 00 -tgtlss 00 I0010:I0230 I0140:I0300
I0210:I0232
Date/Time: 2 de diciembre de 2009 06:29:31 PM GMT IBM DSCLI Version: 5.3.1.183 DS: IBM.2107-75YY491
CMUN03073E mkpprcpath: 00:00: Copy Services operation failure: One or more path establish tasks has failed.
dscli> lspprcpath -l 00
Date/Time: 2 de diciembre de 2009 06:29:55 PM GMT IBM DSCLI Version: 5.3.1.183 DS: IBM.2107-75YY491
Src Tgt State SS Port Attached Port Tgt WWNN Failed Reason
00 00 Success 7000 I0010 I0230 5005076307FFC403 -
00 00 Success 7000 I0140 I0300 5005076307FFC403 -
00 00 Failed 7000 I0210 I0232 5005076307FFC403 Retry Exceeded
External Moderator
Re: IBM PPRC thru DCX does not work out
--->>>Acording to IBM specialists, there is an issue related to login of the F ports ....
--->>>what else can I check in order to find out where the problem is?
I'm not familiar whit IBM and cisco ONS....
check the port settings you want to connect to other device, as example BB Credit, Distance Mode Settings,
Is a extended License Active ?
TechHelp24
Anonymous
Hello!
I resolved this issue with a CP failover
Regards!
Juan I Tellez
New Contributor
Hello Juan,
Could you provide additional information about solution you're used to resolve problem?
We have very similar issues with DCX and IBM pprc.
Thanks,
Andrzej
Anonymous
Hi Juan
Can you please explain how you managed to fix this issue as we are experiencing exactly the same problem
IBM PPRC thru 48000 Directors does not work.
Did you just run these commands to do a CP failover?
"hasyncstart" - to enable the HA sync process
"hafailover" - to initiate the control processor failover
Thanks
Aldyn
