New Contributor
IBM Brocade 8Gb 20-port SAN Switch Module upgrade to 7.x.x?
Hello, have IBM BladeCenter-H with two IBm Brocade 8Gb SAN Switch Module FOS v6.4.2b4, at support portal IBM this is latest FOS for this Switch, who can say any way to upgrade to 7.2.x fw or its not supported platform? thx.
Broadcom Moderator
Re: IBM Brocade 8Gb 20-port SAN Switch Module upgrade to 7.x.x?
Hi,
what is the switchtype displayed in CLI switchshow output?
An 8G switch should be go past 6.4 - you might be a 5470 which shows switch type 73.
New Contributor
Hello Martin
> switchshow
switchName: BCH02_SANSW01
switchType: 73.6
switchState: Online
switchMode: Native
switchRole: Principal
switchDomain: 1
switchId: fffc01
switchWwn: 10:00:00:05:33:a0:b0:54
zoning: ON (ConfigZone01)
switchBeacon: OFF
> version
Kernel: 2.6.14.2
Fabric OS: v6.4.2b4
Made on: Thu Aug 9 21:10:00 2012
Flash: Fri Jan 9 08:28:19 2015
BootProm: 1.0.9
Broadcom Moderator
Hi,
this is a 5470 (brocade speak), and you should be able to upgrade until 7.4.2a (but no 8.x as the 8G platform is not supported under 8.x).   I am not sure why IBM sites stops at 6.4.x, but when looking at our release notes it is clearly supported under 7.x
