New Contributor
I dont know nothing about SAN help me please
HI
Team sorry about my english but need help
I have 2 brocades
2 v5010 ibm
1 v3700
1 x3850 ibm > connect direct to one brocade
i need zonne all ports to this port from server because
like this
Port one is from cannister 1 v5010
Port two canniester 2
port 4 from another server
port5 is my server backup
port 6 7  connect to another switch san
i dont configure this envirnoment
but i create a zone in one switch to find all luns in v3700 ... but i dont find disks in v5010
this server connect in port 5 is microsoft and need see all disks from 3 storages
how i configure zone to port 5 see everthing ?
thanks
Frequent Contributor
Re: I dont know nothing about SAN help me please
Hi,
Can you share more info about your environment  ?
Could you please connect to the switch IP address and run following commands:
switch show
cfgactvshow
nszonemember -a
please run this on both brocades
New Contributor
Follow attached
thanks
New Contributor
Vi agora que voce tem o icone do brasil
eu sou novo aqui e ninguem meche no ambiente, meu chefe tambem nao entende nada
eu entendo um pouco basicamente
eu queria que esse server de backup estivesse na mesma zona para ver todos os discos dos 2 storages
queria aprender como configuro uma zona assim nos switchs pela porta e se tem algum perigo zoar algo tipo lun de alguem tipo mesmo disco pra duas luns sei la
se posso fazer isso que tambem nao sei se posso
e com melhor pratica para incluir esse servidor ou esse wwn ou essa porta 5 em todos os grupos para ele poder ver todos os discos,
pq estiver no mesmo grupo so preciso ir dentro do storage e mapear pra lun aqueles discos ou aqueles grupos de discos
[ Edited ]
Hi Baduba,
I'm Brazilian, but since this Board is intended to help all people around the world, I prefer to write here in English.
As seen in your logs, you do not have a zone configuration database, so, you probably have default zonning set to all acess.
you may confirm that with the command  defzone --show
You probably has committed to all acess.
If that is the case, all servers have access to all storage by default. Said that, you need to do a thing called mapping (or masking) on the storage side. this procedure enables a server wwwpn (HBA address) to acces a specified set of luns.
The way your switches are configured are not recommended anymore.
go to redbooks.ibm.com and look for a document called Introduction to storage area networking and learn a bit more about that.
feel free to contact me if you need some help.
Community Manager
@baduba
Thank you for joining the Brocade Community. As @anovelli mentioned this technical forum in English only. Please translate your posts beforehand using this free tool by Google https://translate.google.com/.
Jason
Brocade Community Mgr.
@jason_cmgr
Contributor
baduba,
In your log Switch A and Switch B you have Zoning: OFF, if you not config zoning you have the next message when you use command #cfgshow
Effective configuration:
no configuration in effect
then all the zones that you configured are only created but not enabled, so you need, Create a Zoning and put the zones.
example:
zone1
zone2
zone3
n
Create Zoning:
cfgcreate "zoning name", "zone1;zone2,zone3" or one zone  cfgcreate "zoningname", "zone1"
cfgsave
cfgenable "zoning name"
After that if you use command #cfgshow  you see
cfg:zoning name
zone1
members
zone2
members.
Regards
Hello rocaflqu,
Thats right. But since he had limited knowledge on SAN, I recommended him learn a bit more about SAN Zonning before make a big change in his fabric.
I helped him in our native language by email so I'm here to give a feedback about that.
Since he has defzone set to all access, all devices reaches all devices. The problem was a missing mapping inside the storage. After he created a host object, added hba ports to it and assigned to the masking, the problem was solved.
He has a lot of homework to do. He created an ALIAS object in the SAN, with wwpn's and wwnn's of several devices, there was not an active configuration, and there was some other minor changes to do. But i recommended him to read more before start doing changes.
Thanks for your engagement into his problem too. Have a nice day!
New Contributor
could you please suggest me hitachi SAN document.
External Moderator
jeba.roji@infosys.com
if you are looking for HDS Storage, post please such question by HDS at
https://community.hds.com/welcome
TechHelp24
