Anonymous
I am having troubles trying to upgrade firmware on a Brocade 300.
Brocade 300 firmware 7.0.0 to 7.2.1c.
I have downloaded the firmware and expanded it on a server with ftp services. When I try to run the upgrade, I get  errors, user name and password or path is invalid. I can manually ftp to my ftp server. I also tried to use USB upgrade. Formated the stick to fat32 and copied the firmware expanded to the stick.
Cannot enable the usb port. Does not mount and switch does not see USB port. Can I manually mount port while in telnet?
The Brocade has been sitting in the box since May 2013.
What else can I look at ?
Any sugguests will be apreicated.
External Moderator
Re: I am having troubles trying to upgrade firmware on a Brocade 300.
You need Genuine Brocade USB Driver, generic USB Driver ( SanDisk, Kingston, etc... ) are not supported.
TechHelp24
