Anonymous
How to totaly clean up DS switches
Hello
We manage a small datacenter that is used for training, at the end of the week we need to clean up multiple switch
so they are ready for the next class.
is there a single commnad that can remove all the virtual switches and disable VF?
or is it possible to load a blank config to the switch that will overwrite any VF config?
Many thanks
External Moderator
Re: How to totaly clean up DS switches
see this thread,
http://community.brocade.com/message/23673#23673
however I've no tested with VF
TechHelp24
Anonymous
Thanks for link, but the command does not affect VF all are left behind.
i will test to see if it can be run against different FID#
Anonymous
Sorry yes the command does clean VF if the "chassisdisable" option is used instead of switchdisable.
Many thanks for the Help..
