Anonymous
How to solve FCoIP with two firewall and two NAT?
[ Edited ]
In my case,I want to implement a DR by HP P6000 over FCoIP.
My topology as follow:
P6000storage==HP 1606(B7800)--(NAT)--Firewall---Firewall--(NAT)--HP 1606(B7800)==P6000Storage
                              ge0:172.16.0.128   a.b.216.35                a.b.0.81      ge0:172.20.1.81
                               gw:172.16.0.254                                                         gw:172.20.0.20
Hp 1606's firmware is v7.0.0c.The only License is "Enhanced Group Management license" by licenseshow.
Routes with domain id 31 & 32.
I do as follow,by no fcipcircuit can create,alway in "InProg" status. my steps:
local:
portcfgpersistentdisable 16-23
portcfg ipif ge0 create 172.16.0.128 255.255.255.0 1500
portcfg iproute ge0 create a.b.0.0 255.255.255.0 172.16.0.254
portcmd --ping ge0 -s 172.16.0.128 -d a.b.0.81 ##ping ok
portcfg fciptunnel 16 create a.b.0.81 172.16.0.128 100000
portcfg fcipcircuit 16 create 1 a.b.0.81 172.16.0.128 100000
portcfgpersistentenable 16
remote: portcfg ipif ge0 create 172.20.1.81 255.255.0.0 1500
portcfg iproute ge0 create a.b.216.0 255.255.255.0 172.20.0.20
portcmd --ping ge0 -s 172.20.1.81 -d a.b.216.35
portcmd --traceroute ge0 -s 172.20.1.81 -d a.b.216.35 ##ping ok
portcfg fciptunnel 16 create a.b.216.35 172.20.1.81 100000 -c 2
portcfg fcipcircuit 16 create 1 a.b.216.35 172.20.1.81 100000
admin> portshow fcipcircuit all
------------------------------------------------------------------------------- Tunnel Circuit OpStatus Flags Uptime TxMBps RxMBps ConnCnt CommRt Met ------------------------------------------------------------------------------- 16 1 ge0 InProg ---4--s 0s 0.00 0.00 0 100/100 0
when I call brocade supporter,he told me that 7800 is not support 2 NAT? Is that true ? only have a case,use once NAT,first upgrade firmware,and with many configure
any one can help me ?TKS
Valued Contributor
Re: How to solve FCoIP with two firewall and two NAT?
hi,
try using the -connection-type (default|listener|initiator) parameter. As per the FCIP Admin guide, there could be problems configuring the tunnel in a NAT environment if this parameter is not configured.
rgds
Anonymous
tks,I will test it tomorrow
Is that mean I must create 2 tunnel for send  & receive.
try -C 2,initiator.
>portcfg fciptunnel 16 create a.b.0.81 172.16.0.128 100000 -C 2
 Tunnel Circuit  OpStatus  Flags    Uptime  TxMBps  RxMBps ConnCnt CommRt Met/G
 16     0 ge0     Disable -I-4--s       0s    0.00    0.00    0   100/100   0/-
 Flags: circuit: s=sack v=VLAN Tagged x=crossport 4=IPv4 6=IPv6
                 L=Listener I=Initiator
Anonymous
[ Edited ]
,update my topology
P6000storage==HP 1606(B7800)--(NAT)--Firewall---Firewall--(NAT)--FW(NAT)---HP 1606(B7800)==P6000Storage
                              ge0:172.16.0.128   a.b.216.35                a.b.0.81        ?        ge0:172.20.1.81
It's with twice NAT remotesite......
after configure --conection-type with I & L at two site.portshow fcipcircuit still Inprog status. VE port is offline
dl_1606
 16     0 ge0     InProg  -I-4--s       0s    0.00    0.00    0  1000/1000  0/-
sy_1606:admin> portshow fcipcircuit all
 16     0 ge0     InProg  -L-4--s       0s    0.00    0.00    0  1000/1000  0/-
I test 3225 port with nmap.
nmap -sU IP -p 3225
service all up at a.b.216.35 & a.b.0.81.
Any more advice?
External Moderator
hi,
-->>Hp 1606's firmware is v7.0.0c.The only License is "Enhanced Group Management license"
show to me you have "base model" 6+2
since remain port's and feature are not licensed, the VE Port show offline.
however, I've answered to you email, would suggest you send me all this details, I'll try to help you with the issue if is one.
TechHelp24
