New Contributor
Accepted Solution
How to shutdown Brocade SAN switch 300
How can i shut down SAN 300 switch and turn on.
Super Contributor
Re: How to shutdown Brocade SAN switch 300
Hello,
correct shutdown of FOS is with command: "sysshutdown"
This command will not power off switch but will umnout FOS so than after couple of minutes (approx. 2 mins) you have to disconnect power cable to shutdown switch completely.
Switch will boot up automatically when you disconnect and connect cable back to the switch.
Brocade 300 doesnt have on/off switch.
Please mark this response as "Accept as Solution" if it answers your question.
Marian Bezeg
New Contributor
Thanks for your reply...
