Anonymous
Re: How to set up an ISL between brocade DS 5000B and DS 5100 switch?
Wouldn't it be better to set the fabricprincipal priorities before joining the switches?
Anonymous
Most of the times- it doesn't matter.
My prefer is to do it after merging. In this situation the fabric already merged correctly (hopefully) and you free to play with it...
Anonymous
Here is what I see when I run the fabric show command
DS500B( Present production, principal)
GAISANSW01:admin> fabricshow
Switch ID   Worldwide Name           Enet IP Addr    FC IP Addr      Name
  1: fffc01 10:00:00:05:1e:90:36:ad 10.211.198.243  0.0.0.0        >"GAISANSW01"
Here is the output of DS5100 new switch( which will become principal later)
GAISANSW03:admin> fabricshow
  3: fffc03 10:00:00:05:33:72:21:a4 10.211.109.33   0.0.0.0        >"GAISANSW03"
GAISANSW03:admin>
Any suggestions ?????
Thanks in advance
Anonymous
Is this before or after you've ISLed (connectet) both switches to each other?
If its before you're still ok.
If its after you have a semented fabric or an port is misconfigured or you don't have the right license.
Can you post a licenseshow, cfgshow, switchshow of each switch?
Anonymous
Everything is well.
In current situation they different fabrics and both of the prinipal of themselves.
Continue with my procedure. If the switch is new one- you don't need to remove it's configuration.
Anonymous
Are you two colleagues of each other or something?
From gauravgupta question you might think both switches are linked together but failed to merge into on fabric.
Anonymous
Hello ELi,
Here is the procedure I am going to follow as per ur suggestion:
Task: To set up ISL between Brocade DS 5000 B( principal, production switch) and DS5100 ( new switch, will become principal once ISL is setup).
Note: Need a down time window to perform the activity.
Note: DS5000B will up upgraded to Firmware OS 6.4.2 before moving to ISL setup.
Note: preform a cfgsave to safe the existing configuration.
1. Clear the new switch zoning configuration with command cfgclear on new Ds5100B if any.
2. Check the native operation mode is set to same on both the switch, check the domain ID are different.
Output:
a) DS5000B (production, principal switch)
GAISANSW01:admin> switchshow
switchName:     GAISANSW01
switchType:     58.2
switchState:    Online
switchMode:     Native
switchRole:     Principal
switchDomain:   1
switchId:       fffc01
switchWwn:      10:00:00:05:1e:90:36:ad
zoning:         ON (GAI_B)
switchBeacon:   OFF
b)DS5100 (new switch, will become principal switch one we connect the ISL)
GAISANSW03:admin> switchshow
switchName:     GAISANSW03
switchType:     66.1
switchState:    Online
switchMode:     Native
switchDomain:   3
switchId:       fffc03
switchWwn:      10:00:00:05:33:72:21:a4
zoning:         OFF
switchBeacon:   OFF
FC Router:      OFF
FC Router BB Fabric ID: 128
Address Mode:   0
3.Defautlt zone policy must be same on both the switches
output:
DS5000B
GAISANSW01:admin> defzone --show
Default Zone Access Mode
        committed - All Access
        transaction - No Transaction
GAISANSW01:admin>
DS5100
GAISANSW03:admin> defzone --show
GAISANSW03:admin>
4.Select ports two on each and make sure there property is E type and auto
DS5000B : ports are 24, 26, allowed E type, Ftype and speed is auto
DS5100 : ports are 24, 26, allowed E type, Ftype and speed is auto
5. Save the current configuration on production before we proceed with ISL link up.
run cfgsave and store in safe place.
6.Run the fiber cables between the selected ports
eg port 24, DS5000B ------------------port 24, DS5100
   port 26, DS5000B ------------------port 26, DS5100
7. Give some time for fabric to settle down and prepare verify cfgshow output is same on both the switches ISL ed.
8. Run the fabric principal command to on the new DS5100 to make it the principal switch.
#fabricprincipal -f 1
Anonymous
Here is output you requested:
New Switch DS 5100 ( no zones noting , completely new)
GAISANSW03:admin> licenseshow
SeSQeQQyybTfTRfg:
    Fabric license
RccyzycQccSdhz0b:
    First Ports on Demand license - additional 8 port upgrade license
AQtWrYgSGDMTPmXSSBGQmLgJLL3XHSPYBAYEN:
    Enhanced Group Management license
RDWfmDfQZNGtAC74GE7BCSXPRZCLKCaSB7ZJN:
    8 Gig FC license
GAISANSW03:admin> cfgshow
Defined configuration:
no configuration defined
Effective configuration:
no configuration in effect
switchType:     66.1
switchState:    Online
switchMode:     Native
switchDomain:   3
switchId:       fffc03
zoning:         OFF
switchBeacon:   OFF
FC Router:      OFF
Address Mode:   0
Index Port Address Media Speed State     Proto
  0   0   030f00   id    N8   No_Light    FC
  1   1   030d00   id    N8   No_Light    FC
  2   2   030b00   id    N8   No_Light    FC
  3   3   030900   id    N8   No_Light    FC
  4   4   030e00   id    N8   No_Light    FC
  5   5   030c00   id    N8   No_Light    FC
  6   6   030a00   id    N8   No_Light    FC
  7   7   030800   id    N8   No_Light    FC
  8   8   030700   id    N8   No_Light    FC
  9   9   030500   id    N8   No_Light    FC
10  10   030300   id    N8   No_Light    FC
11  11   030100   id    N8   No_Light    FC
12  12   030600   id    N8   No_Light    FC
13  13   030400   id    N8   No_Light    FC
14  14   030200   id    N8   No_Light    FC
15  15   030000   id    N8   No_Light    FC
16  16   032700   id    N8   No_Light    FC
17  17   032500   id    N8   No_Light    FC
18  18   032300   id    N8   No_Light    FC
19  19   032100   id    N8   No_Light    FC
20  20   032600   id    N8   No_Light    FC
21  21   032400   id    N8   No_Light    FC
22  22   032200   id    N8   No_Light    FC
23  23   032000   id    N8   No_Light    FC
24  24   031f00   id    N8   No_Light    FC
25  25   031d00   id    N8   No_Light    FC
26  26   031b00   id    N8   No_Light    FC
27  27   031900   id    N8   No_Light    FC
28  28   031e00   id    N8   No_Light    FC
29  29   031c00   id    N8   No_Light    FC
30  30   031a00   id    N8   No_Light    FC
31  31   031800   id    N8   No_Light    FC
32  32   031700   --    N8   No_Module   FC  (No POD License) Disabled
33  33   031500   --    N8   No_Module   FC  (No POD License) Disabled
34  34   031300   --    N8   No_Module   FC  (No POD License) Disabled
35  35   031100   --    N8   No_Module   FC  (No POD License) Disabled
36  36   031600   --    N8   No_Module   FC  (No POD License) Disabled
37  37   031400   --    N8   No_Module   FC  (No POD License) Disabled
38  38   031200   --    N8   No_Module   FC  (No POD License) Disabled
39  39   031000   --    N8   No_Module   FC  (No POD License) Disabled
GAISANSW03:admin>
DS5000B ( presently in production, principal, will be removed onceISL is establised and all fiber connections are moved to new DS5100)
GAISANSW01:admin>  licenseshow
SSbeSSycz9TTcfTR:
    Unknown1 license
bbyySdz9QRcczzTr:
    Unknown2 license
Rcddy9zSdeezl:
    Fabric license
bRSbe9ebedcSXcfG:
    Second Ports on Demand license - additional 8 port upgrade license
bRSbe9ebedciTcfS:
switchType:     58.2
switchState:    Online
switchMode:     Native
switchDomain:   1
switchId:       fffc01
zoning:         ON (GAI_B)
switchBeacon:   OFF
Area Port Media Speed State     Proto
  0   0   id    N2   Online           F-Port  50:06:01:60:30:20:92:81
  1   1   id    N4   No_Light
  2   2   id    N4   No_Light
  3   3   id    N4   Online           F-Port  10:00:00:00:c9:76:11:dc
  4   4   id    N2   Online           F-Port  50:06:01:69:30:20:92:81
  5   5   id    N4   No_Light
  6   6   id    N4   No_Light
  7   7   id    N4   No_Light
  8   8   id    N4   No_Light
  9   9   id    N4   No_Light
10  10   id    N4   Online           F-Port  10:00:00:00:c9:61:ab:e3
11  11   id    N4   Online           F-Port  5 NPIV public
12  12   id    N4   Online           F-Port  4 NPIV public
13  13   id    N4   Online           F-Port  5 NPIV public
14  14   id    N4   Online           F-Port  4 NPIV public
15  15   id    N4   Online           F-Port  5 NPIV public
16  16   id    N4   Online           F-Port  4 NPIV public
17  17   id    N4   Online           F-Port  8 NPIV public
18  18   id    N4   Online           F-Port  20:0f:00:05:1e:ca:9a:4c
19  19   id    N4   No_Light
20  20   id    N4   No_Light
21  21   id    N4   No_Light
22  22   id    N4   No_Light
23  23   id    N4   No_Light
24  24   id    N4   No_Light
25  25   id    N4   No_Light
26  26   id    N4   No_Light
27  27   id    N4   No_Light
28  28   id    N4   No_Light
29  29   id    N4   No_Light
30  30   id    N4   No_Light
31  31   id    N4   No_Light
cfgshow
cfg:   GAI_B
zone:  ESXBP01GAIWV_1_CX500_SPA0
                21:00:00:24:ff:29:92:bd
zone:  ESXBP01GAIWV_1_CX500_SPB1
zone:  ESXBP02GAIWV_1_CX500_SPA0
                21:00:00:24:ff:22:ae:a7
zone:  ESXBP02GAIWV_1_CX500_SPB1
zone:  ESXBP03GAIWV_1_CX500_SPA0
                21:01:00:1b:32:bd:6e:40
zone:  ESXBP03GAIWV_1_CX500_SPB1
zone:  ESXBP04GAIWV_1_CX500_SPA0
                21:01:00:1b:32:bd:56:81
zone:  ESXBP04GAIWV_1_CX500_SPB1
zone:  ESXBP05GAIWV_1_CX500_SPA0
                21:00:00:24:ff:29:90:f5
zone:  ESXBP05GAIWV_1_CX500_SPB1
zone:  ESXBP06GAIWV_1_CX500_SPA0
                21:00:00:24:ff:29:92:6f
zone:  ESXBP06GAIWV_1_CX500_SPB1
zone:  ESXBP07GAIWV_2_CX500_SPA0
                21:00:00:24:ff:29:92:6d
zone:  ESXBP07GAIWV_2_CX500_SPB1
zone:  WD21COLD5C_1_CX500_SPA0
zone:  WD21COLD5C_1_CX500_SPB1
zone:  bc7b02viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:26:f0
zone:  bc7b02viosr_fcs1_CX500_SPB1
zone:  bc7b04viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:69:f0
zone:  bc7b04viosr_fcs1_CX500_SPB1
zone:  bc7b06viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:f6:f0
zone:  bc7b06viosr_fcs1_CX500_SPB1
zone:  bc7b08viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:e8:f0
zone:  bc7b08viosr_fcs1_CX500_SPB1
zone:  bc7b10viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:65:f0
zone:  bc7b10viosr_fcs1_CX500_SPB1
zone:  bc7b12viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:63:f0
zone:  bc7b12viosr_fcs1_CX500_SPB1
zone:  bc7b14viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:c9:f0
zone:  bc7b14viosr_fcs1_CX500_SPB1
zone:  bc8b02viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2e:f7:7a
zone:  bc8b02viosr_fcs1_CX500_SPB1
zone:  bc8b04viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2e:c5:7a
zone:  bc8b04viosr_fcs1_CX500_SPB1
zone:  bc8b06viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2e:24:7b
zone:  bc8b06viosr_fcs1_CX500_SPB1
zone:  bc8b08viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2e:3a:0e
zone:  bc8b08viosr_fcs1_CX500_SPB1
zone:  bc8b10viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:25:07:e9
zone:  bc8b10viosr_fcs1_CX500_SPB1
zone:  bc8b12viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2e:4b:0e
zone:  bc8b12viosr_fcs1_CX500_SPB1
zone:  bc8b14viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:27:67:76
zone:  bc8b14viosr_fcs1_CX500_SPB1
zone:  bc9b02viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:72:ac
zone:  bc9b02viosr_fcs1_CX500_SPB1
zone:  bc9b04viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:6c:ab
zone:  bc9b04viosr_fcs1_CX500_SPB1
zone:  bc9b06viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:73:ac
zone:  bc9b06viosr_fcs1_CX500_SPB1
zone:  bc9b08viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:3b:ac
zone:  bc9b08viosr_fcs1_CX500_SPB1
zone:  bc9b10viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:e0:ab
zone:  bc9b10viosr_fcs1_CX500_SPB1
zone:  bc9b12viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:25:ac
zone:  bc9b12viosr_fcs1_CX500_SPB1
zone:  bc9b14viosr_fcs1_CX500_SPA0
                21:01:00:1b:32:2b:b7:ac
zone:  bc9b14viosr_fcs1_CX500_SPB1
zone:  esx1p01gaiwv_2_CX500_SPA0
                10:00:00:00:c9:6f:3d:fa
zone:  esx1p01gaiwv_2_CX500_SPB1
zone:  esx1p02gaiwv_2_CX500_SPA0
                10:00:00:00:c9:6f:3d:c3
zone:  esx1p02gaiwv_2_CX500_SPB1
zone:  esx1p03gaiwv_2_CX500_SPA0
                20:00:00:00:c9:72:73:6c
zone:  esx1p03gaiwv_2_CX500_SPB1
zone:  esx1p04gaiwv_2_CX500_SPA0
                20:00:00:00:c9:64:d2:f9
zone:  esx1p04gaiwv_2_CX500_SPB1
zone:  esx1p05gaiwv_2_CX500_SPA0
                20:00:00:00:c9:6f:3d:fd
zone:  esx1p05gaiwv_2_CX500_SPB1
zone:  wbrpgai01a_fcs1_CX500_SPA0
zone:  wbrpgai01a_fcs1_CX500_SPB1
Note: Lion , what I am trying to achieve is to set up ISL between old switch and new switch, move the fiber connection to new switch , make it principal one and retire the old switch.
Thanks again
Gaurav
Anonymous
Yeah understand what you're trying to achive.
From your post http://community.brocade.com/message/22881#22881 second to last line
It looked (at least to me) you had an issue AFTER the switches are ISLed.
From what I understand now that it's not the case.
Anonymous
In reply to http://community.brocade.com/message/22886#22886
I would run a configupload to an ftp server, or use dcfm/bna.
That would store zoning and switch config in a save place.
cfgsave only saves the zonedatabase to the switch cf card.
