Anonymous
How to monitoring link status between Brocade 48K and devices
Hi all,
How to monitoring link status between Brocade 48K and devices,
I found if link have a problem with FC Cable or SFP in Devices there is no messages produce in Brocade.
Any sugestion how monitoring with CLI or GUI ?
best regards
External Moderator
Re: How to monitoring link status between Brocade 48K and devices
Whit Performace Minitoring, a License is Requiered.
or Third Parts Tools.
TechHelp24
Occasional Contributor
If you have Fabric Manager installed, you can set up a change report that will email you when device links change. If you are good at scripting, you could accomplish the same thing using SNMP alerts.
Anonymous
How about from CLI, any command to monitoring the status link ?
External Moderator
"nsshow"
TechHelp24
