New Contributor
How to monitor ISL on the switch which does not have trunking license
Hi,
How to monitor ISL on the switch which does not have trunking license?
I have created ISL between two switches, both the switches does not have trunking license. Please let me know the posaable ways to monitor the ISL's .
External Moderator
Re: How to monitor ISL on the switch which does not have trunking license
"islshow"
TechHelp24
New Contributor
Hi,
islshow is giving the information about the ISL's only. I need to check the bandwidth utilization and metrics cost.
External Moderator
[ Edited ]
you ask for monitoring ISL, and not about traffic or utilization.
-->>>>How to monitor ISL on the switch which does not have trunking license?
with the command "portperfshow" you can get the info you need.
all this details are descripted as well in Command Reference Manual.
BTW, Trunking License is another story, and have nothing to do with Port Monitoring or similary.
TechHelp24
New Contributor
Thanks for your help.
I wanted to see the output like trunkshow command. I got the details with the help of portperfshow -rx -tx .
