Occasional Contributor
How to enable FPI monitoring
Our switch SN6520 has FOS 8.0.1 I would like to know how to enable and use FPI monitoring without the need to purchase license of Fabric vision and MAPS? Is it possible? Regards, vplucky2
External Moderator
Re: How to enable FPI monitoring
@vplucky2
moved the thread in corect forum.
in order to enable FPImon, MAPS must be configured, and a FabricVision capable license is mandatory.
TechHelp24
Broadcom Moderator
Notice the following
In Fabric OS 8.0.1 and later releases, fabric performance impact monitoring no longer requires a Fabric Vision license; it is
enabled by default
Hi, If the FPI monitoring is enabled by default, then how to check it? how to perform its monitoring? I mean does it have a separate URL or a separate application to be installed? Need this to monitor our SAN environment
Broadcom Moderator
[ Edited ]
Hello,
The best is to read the command reference guide as well as admin guide around MAPS.
MAPS can provide alerts to RASLOG, by email or through SNMP. There is no external application to load. BNA can be useful because there is an integration of MAPS on it.
Try commands:
mapsdb --show all
mapsconfig --show
Check if default MAPS configuration is as you are expecting for reporting.
Hi, Sorry for delayed reply. PFB the command output. FID128:admin> mapsdb --show all Fabric vision license not present. Please install the license and retry the operation. FID128:admin> mapsconfig --show Configured Notifications: SW_CRITICAL,SW_MARGINAL Mail Recipient: ABCD@XYZ.com Paused members : =============== PORT : CIRCUIT : SFP :
