Anonymous
How to do Periodic Maintenance for Brocade SAN Switch B64/B80/384B/768B
I am a new Network Engineer.
How to do Periodic Maintenance for Brocade 2005-B64 2498-B80 2499-384B 2499-768B SAN Switch?
What items to check and what commands should be used.
Is there formal papaer-format PM report?
Thanks reall a lot to listen from you.
Anonymous
Re: How to do Periodic Maintenance for Brocade SAN Switch B64/B80/384B/768B
Hi, perhaps you could explain what you want to find out from your Periodic Maintenance?
As some commands may not be available in all Fabric OS versions - presumably which FOS version the switch is running is an important first step.
You can find details of all the commands in the Brocade Fabric OS Command Reference - they are available per each Fabric OS version.
If you want a good overview of how the switch is doing - see the output of the command 'supportshow'.
Frequent Contributor
Depending on what your goals are with respect to periodic maintenance SAN Health could be a
cohesive solution. As a result of using SAN health you will be able to perform key tasks such as:
  • Taking inventory of devices, switches, firmware versions, and SAN fabrics
  • Capturing and displaying historical performance data
  • Comparing zoning and switch configurations against best practices
  • Assessing performance statistics and error conditions
  • Producing detailed graphical reports and diagrams
and much more.
Please see the links below for additional detail on SAN Health:
Brocade SAN Health
http://community.brocade.com/docs/DOC-2662
http://community.brocade.com/docs/DOC-2665
