New Contributor
Accepted Solution
How to connect two virtual switch?
Good day.
On Brocade5300 creates two virtual switch. Each virtual switch from one port.
How to connect them to each other? Is it possible to combine them without a physical commutation?
PS Sorry for my bad english.
Valued Contributor
Re: How to connect two virtual switch?
If these two VFs are sharing the same chassis, then you can only connect them with external FC cable, and then one of these VFs has to be configured as FCR.
New Contributor
Alexey, thank you very much for your response. I just thought that there are mechanisms without using a cable.
