Anonymous
How to connect two FC-Switches
Hi
I want to connect two Brocade FC-Switches.
When I do that I see on Switch1:
>switchshow
Area: 3
Port:  3
Media: id
Speed: N2
State: Online E-Port segmented,(disabled E_Port)
Switch2:
>switchshow
Area: 4
Port: 4
Media: id
Speed: N2
State: Online E-Port segmented,(No Fabric License)
So my question is: Do I need a fabric license just to connect two Broace FC-Switches together? We only have a small SAN and I do not need any special features on the switches (no zoning,..).
Andreas
External Moderator
Re: How to connect two FC-Switches
each switch must have unique Domain ID.
you can verify Domain ID with command "switchshow"
yes, Fabric License is required in order to build a fabric.
TechHelp24
Anonymous
Hi
Please help me with the understanding of "fabric".
I do have network knowledge but I do not have much FC-knowledge.
So what I wanted to have is to connect both FC-switches together (no trunk) so that all connected devices on both switches can see each other. Is this called a fabric?
On ethernet-switches connecting two switches with each other is no problem, so I thought this would be the case with FC-Switches as well...
Andreas
External Moderator
Andreas,
--->>>On ethernet-switches connecting two switches with each other is no problem, so I thought this would be the case with FC-Switches as well...
Is not the same as SAN Switches. Switch my partecipate in the same FABRIC, must have a Fabric License.
"licenseshow" command give the output of installed license.
TechHelp24
Anonymous
1's and 0's ...: HP SAN Switch E-Port segmented, (No Fabric License)
First hit on Google if you look for the State description.
Have fun!
Anonymous
I tried google yesterday for hours...
All I was not sure was if I need a fabric license just to connect two FC-Switches or if the fabric license is neccessary for some "advanced" features...
