Anonymous
How to connect Brocade switch and Qlogic switch ?
We have IBM 2498-B24 (firmware 6.4.1b) and four IBM BladeCenter E.  One BladeCenter E has two IBM / Qlogic 43W6724.  One BladeCenter E has two IBM / Qlogic 44X1905.  Two has Brocade modules.
The problem is that during SAN zoning config on 2498-B24, the config will be lost after 5 minutes.
I heard that it needs to modify brocade port id to 2.  May I know how to modify the port id ?
External Moderator
Re: How to connect Brocade switch and Qlogic switch ?
Some Old QLogic Blade Switch are not longer supported and cannot ISL's to NEW Brocade FOS Release.
--->>>IBM / Qlogic 44X1905
this Blade is unknown to me, or better to say I've newer work with this Blade.
Can you point me to Support URL, DOC, FW, release Notes etc ? I'll check some details and let you know if this can be ISL'' to Brocade or not.
Message was edited by: TechHelp24
TechHelp24
External Moderator
In the meantime....
I'm testing another Brocade-to-QLogic config, and found this Info here.
http://delivery04.dhe.ibm.com/sar/CMA/XSA/02l2f/1/qlgc_fw_bcsw_7.10.1.20_anyos_noarch.txt
is the the FW Loaded in you Blade Switch 44X1905 ?
TechHelp24
Anonymous
44X1905 firmware 7.10.1.11
43W6724 firmware 6.5.0.25
